Dynamat extreme question
fbm211
fbm211 Posts: 1,488
edited April 2010 in DIY, Mods & Tweaks
Im going to do the dynamat and mortite tweak soon.Ordering the stuff tonight.Would two 10 X 10 sheets (Dynamat extreme) be enough for a pair of 2Bs ?? 9.95 w/free shipping a good price?
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    The mortite is kind of expensive with shipping.Anyone have some you would consider selling?I dont think I need a whole package anyway.
  • Face
    Face Posts: 14,340
    edited April 2010
    My local K-Mart/Sears had it on clearance for $3.50.
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    Well thats a-lot better than 5.99 + 8.00 shipping.Im looking on bing now and finding a lot of much better deals than on ebay.Ebay can sometimes be such a rip off.I just cant understand the prices some people pay for stuff there.Idiots too lazy too shop around.
  • skrol
    skrol Posts: 3,487
    edited April 2010
    Your local Lowes or HD should have Moretite.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zingo
    zingo Posts: 11,258
    edited April 2010
    I found mine at Fred Meyer. Also most any store with a home maintenance section should have it.
  • headrott
    headrott Posts: 5,496
    edited April 2010
    Fred Meyers has it? I will be picking some up then. What was the price on it?
    Greg
  • zingo
    zingo Posts: 11,258
    edited April 2010
    Under $5 I think; pretty cheap either way.
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    Thanks all.
    Dynamat extreme and mortite on the way.
    Cant wait to apply these tweaks to hear what everyone's been talking about.
    Ill have something to do next friday.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    fbm211 wrote: »
    Thanks all.
    You're going to hit the floor when you hear the improvement. Do you have them spiked?
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    Not yet.I have those things you insert into the wood or mdf to screw the spikes into.(The larger Mye spikes) I have 4> 11.5 x 16.5 x 1 solid wood (ash) but changed my mind and plan to go with mdf.After I get my read on about exotic wood veneer and how to best do it, that will be my next project.I just have to find someone to cut it to spec and round off the front edges.I currently have the 2Bs sitting on ceramic tiles.
  • hearingimpared
    edited April 2010
    fbm211 wrote: »
    I think you are talking about 'T' nuts. PM Jesse (F1nut) he'll get you straight on how to get them inserted properly. Great choice on the MYE Sound spikes, they are the best in the business. Wait till you hear how they transform the bass.
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    Yes 'T' nuts is correct.Courtesy of another polkie who had too many.
  • zingo
    zingo Posts: 11,258
    edited April 2010
    Has anyone used any of the liquid sound deadeners instead of the mat in/on their speakers?
  • hearingimpared
    edited April 2010
    fbm211 wrote: »
    Ah yes, I remember that.:)
  • hearingimpared
    edited April 2010
    zingo wrote: »
    There are a couple of theads where someone used some kind of spray deadening material in lieu of Dynamat. The name of the product eludes me right now but if you do a search on Dynamat throughout the forum it may show up in one of those threads.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    I wouldn't worry too much about using the actual Mortite brand. Rope caulk is rope caulk. It's all the same stuff.
    I did the "Mortite" mod to my 2A's a while back, using a random brand of rope caulk that I found at Ace Hardware...and I'm absolutely floored with the improvements that it's made. I think the rope caulk cost me about $2.50 or so. They'll have it at any hardware store/home improvement store...and probably even Walmart. Don't spend the extra on shipping.
    I can't imagine the actual Mortite brand making any difference. It's the exact same stuff.
    You should be able to get the Dynamat at any local place that does car audio installations.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    F1nut Posts: 52,253
    edited April 2010
    zingo wrote: »
    Do you mean on the driver baskets or the interior walls of the cabinet?
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    And Done..I have done both tweake and I have a much cleaner sound.Thanks all.
    Face--You didnt have to sent that mortite rush shipment.Very nice of you to do that.Thank You.
  • hearingimpared
    edited April 2010
    fbm211 wrote: »
    Excellent, another satified customer!:D Now, SPIKE 'EM!;)
  • Face
    Face Posts: 14,340
    edited April 2010
    fbm211 wrote: »
    No problem, it was because of this post.
    fbm211 wrote: »
    Thanks all.
