Can i fix a driver that is stuck?
JacobJacob Posts: 2
edited July 2001 in Technical/Setup
I have an older pair of Monitor 7C's Recently one of them seized up. If try to move it by hand it has no give. Is there a way to fix this or do i have to replace it.
Jacob
Post edited by Jacob on
  • sgtgtosgtgto Posts: 310
    edited July 2001
    Hi:
    I would replace it. If it seized up once it probably will again.
    Gary
  • RuSsMaNRuSsMaN Posts: 17,995
    edited July 2001
    What Gary said, do it.
    Cheers,
    Russ
  • TroyDTroyD Posts: 12,638
    edited July 2001
    I just had one do the same thing and am replacing it.....
    Troy
  • JacobJacob Posts: 2
    edited July 2001
    Thanks you all
    I will order the replacement and continue to enjoy my Polk sound.
    Jacob
  • mjmcgmjmcg Posts: 102
    edited July 2001
    If it siezed up under normal use, replace it...if it took a hit (dropped) take the driver out, and tap on the ceramic part of the magnet gently with a plastic mallot ot the likes to reallign the motor structure slot around the voice coil assembly. Depending on the circumstances, it can be done.
    mike
  • BobMcGBobMcG Posts: 1,613
    edited July 2001
    We've fixed and replaced 'em.
    polkaudio speakers: SDA-SRS-2.3 (modified) SDA-2B SDA-CRS+ RT3000p CS400i LF-14 Monitor 7B
Howdy, Stranger!
