Hanging Rear Center
iDoNtKnOe2k1
Well i have an old cs275 that i would like to hang as my rear center with my brand new Denon 3802
My question is that:
If i screw in screws into the speaker will it damage the speaker in anyway...
I would like to screw in some brackets to hang the speaker on the wall (actully its hanging by some rope now)
Post edited by iDoNtKnOe2k1 on
Shouldn't hurt a thing, except maybe re-sale value....
Just use common sense before you get your drill on, maybe pop a driver out and see what-is-where first.....
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
The Russman is right.
I called ken at polk customer service before drilling my cs400, you can see it hanging in "system showcase". He said if you drill on the sides, it would be ok.
I used the omni mounts, worked out well.
-Luc -
Rope? Rope? Jeezuz......
I generally prefer silver duct tape for my half-assed projects.
BDT.....you half-assedOh, the bottle has been to me, my closes friend, my worse enemy!
