SDA2 ?'s
mhw58
mhw58 Posts: 359
edited October 2002 in Speakers
I just bought a pair of SDA2's used for $200! I feel very
lucky to have these speakers but I don't know much about them.
They did not come with the interconnect cable. Does the cable
make a big difference in the sound and imaging of the speakers?
Does Polk still sell the cable? My speakers say SDA II, how do
I know if they are 2a's, 2b's, 2c's etc? What is your opinion
of these speakers? Thanks for any info on them, Mike
mhw58@yahoo.com
Fronts: SDA1C's
Rears: SDA2's
Center:CS400i
Sub: PSW505
Post edited by mhw58 on
    F1nut Posts: 49,832
    edited July 2002
    mhw58
    Check your email. Welcome to the forum.
    F1nut and all the other nuts on here.
  • richlentz
    richlentz Posts: 4
    edited July 2002
    MHW58;
    I would guess you have the SDA "A" series, I happen to have the SDA 2B they are marked on the rear of the speakers. Most likely the SDA 2A's did not say 2A because they did not plan on updating them. They are good sounding speakers, when you get the chance you can order the cable from parts department. Sounds like you got a very good deal! Enjoy:D
  • har_navalta
    har_navalta Posts: 957
    edited July 2002
    If you cannot buy or get an Interconnect cable I can help
    you make your own...
    Har
  • rdegaeta
    rdegaeta Posts: 1
    edited July 2002
    I actually thought my speakers were the SDA-2's for the longest time -- until I had to replace a driver. All of the individual speakers are labelled on the back with "SDA-2B"... there's nothing on the back of the cabinets to indicate that. Go figure!
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    Does your 2's have 1 tweeter or 2 tweeters in each
    speaker? How many midranges? Apparently the original
    2's have 2 tweeters and 3 midrange while the 2A's
    and B's had 1 tweeter and 2 midranges.
    Thanks, Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • capitan100
    capitan100 Posts: 172
    edited October 2002
    Good luck with your sda-2's. I love mine. I have a pair of 2b's
    Sony DA7ES 7.1 A/V Receiver
    Sony DVP-NC80V - SACD/DVD player
    CS400 - Center channel
    RT2000i - Fronts
    RT1000i - Surrounds
    a/d/s MS3/u - subwoofer
    Hitachi 62 inch HD TV
    2 Channel Room
    Niles HDL-4 Speaker Selector
    Niles HDL-6 Speaker Selector
    Sony V555ES receiver
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
    Wharfedale Valdus 100SE
    Polk PSW 350 - subwoofer
    Pioneer Elite Big Screen
