Need Help Identifying these Polk Speakers
c2v
c2v Posts: 3
edited March 2005 in Vintage Speakers
I have a pair of Polk Speakers. 2 - 6.5" Woofers, 1 - 12" flat passive radiator, and 1 - Peerless tweeter mounted in the cabinet, not on top. Real walnut veneer. And Sits on a matching walnut base. I will include a photo if no one is able to ID by description. Please help.
Post edited by c2v on
  • danger boy
    danger boy Posts: 15,722
    edited March 2005
    a photo will make things much easier. several vintage Polks come to mind.
    also.. look at the rear of the speaker(s) for the serial number.. the first couple numbers will usually be a clue as to what it is..
    the serial number may look something like this.. 10B 89772 or 7A 092671
    the first number and letter tells the model number Monitor 7 or Monitor 10, then most Polk speakers went by A,B,C.
    PolkFest 2012, who's going>?
  • BobMcG
    BobMcG Posts: 1,585
    edited March 2005
    ...R.T.A. 11. This would have the two 6.5" mids w/a 1"soft dome tweeter and a 12" PR. (And yes, a picture would help.)
    The Monitor 7s all had only one 6.5" mid and a 10" pr.
    The Monitor 10 family all used two 6.5" mids but had 10" PRs. (Mon-10 had the soft dome tweeter though where the 10B used the 2000 and the Mon-10 series 2 utilized the 2500.)
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited March 2005
    Agreed, (early) RTA 11 or Monitor 11, or possibly SDA2 - depending on if he is talking about a riser, or a separate stand.
    Cheers,
    Russ
  • c2v
    c2v Posts: 3
    edited March 2005
    The serial number does start off with an "11".
    F1nut Posts: 49,806
    edited March 2005
    Those are Monitor 11's, a rare breed.
  • c2v
    c2v Posts: 3
    edited March 2005
    Thanks for your time. However, it seems that the only Monitor 11's that I have seen have had the Silver Coil Tweeter and a 10" Passive.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=71571&item=5752056498&rd=1&ssPageName=WD1V
  • shack
    shack Posts: 11,154
    edited March 2005
    Those speakers (in your e-bay link) were discussed at length here:
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=25631&highlight=monitor+11%2A
    note the 6th reply from Russman
    The early Mon11 came with the sl1000 and a flat 12" PR, IIRC
  • danger boy
    edited March 2005
    c2v hang on to those bad boys.. since they seem to be somewhat rare.. plus they have the much beloved peerless tweeter! Woo Hoo! :D
