Is there such a thing as too much black hole five?
Answers
With mine it just peeled off. It didn't really remove any of the particleboard except for a few Dusty fibres which makes it not really sticky again
I was not able to peel mine away from the board. It separated and left the BH5 base material.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
The adhesive on it is extremely strong. I wonder since analogluvr was able to remove his so easily if that had something to do with his results as it needs to be bonded solidly to the foundation to work properly.Political Correctness'.........defined
President of Club Polk -
Is there any prep recommended or needed before installing?
Not that I'm aware of. The trick is you have press it on hard, you just can't slap it on.Political Correctness'.........defined
^^^^ This and wipe any dust off with a damp rag before application.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
You could dab the area with a little masking or packing tape to pull off any loose fibers.
after a year trial I have now removed the 3" wide strips from the sides of the sda srs and put the size recommended by Dark Knight ...much better !
You guys will get a laugh at my very obvious mistake. I bought some BH-5 from a C/L and he had many scraps all over the place plus the intact sheet I bought for $12. He did mention that there was no stickum on the loose pieces which were the 3"" wide albeit to long. I said I have Liquid Nails and that stuff sticks to anything thing. Well there was a question posed over on AK and sure enough Jesse noticed my mistake. I put the dark side down w/ the LNs then moved on to the other cabinet and saw my miss doings ,scrapped the beat cabinet clean and then used the new sheet and placed it the correct way. Jesse must of been laughing for hours at my expense. Here's what not to do
Post edited by [Deleted User] on2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
And this is why we have deja vu, folks.
I have a piece of this and was considering using it inside my Cornscalas. Where would be the best place to place it?The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Over your ears to squelch the laser bright highs......
Kidding. No clue at all, Travis.... -
Usually its behind the drivers. Is the mid and tweeter both horn driven? I do not know about putting it behind an active bass driver in SDA's and passive radiators we do not put anything down behind that.
Yep, horn mids and tweets. There is not any kind of dampening materials inside the cabinet at all
Thorens TD320
Modified Carver C-1
^^^ oooo! Not a bad idea! I've been using feather pillows!Gustard X26 Pro DAC
