Teac CD disc tray won’t open
Mr. SharpeMr. Sharpe Posts: 1,077
edited June 14 in Troubleshooting
My father gave me an older teac RE-D200 cd recorder and the playback drawer won’t open. I can open the top and push the pickup down and it will open and it will close but I have to pull it back up so it will read the disc.
What could it be? Just old?
Marantz UD-7007 Cd Player
Parasound Halo P5 Preamplifier
Marantz ST-7001 Radio Tuner
Parasound HCA-1500A Power Amplifier
Polk Audio Monitor 10B's
5 channel
Sony Bravia 32" LED
Yamaha RX-a3010 Receiver
Marantz UD-7007 Blu-Ray player
Klipsch RB-61 Main Speakers
Klipsch RB-41 Surround Speakers
Post edited by KennethSwauger on
  • mhardy6647mhardy6647 Posts: 17,991
    edited June 14
    Short answer: I know nothing about that deck, so I really don't know the answer...
    but...
    If the tray is driven by a belt -- the belt is probably stretched, stiff, or disintegrated.
    The ol' Yamaha decks, IME, are notorious for this. I fix 'em - Philistine that I am - with very small rubber bands left over from our kids' orthodontics days :p Not a permanent fix, but cheap (free) and easy. I can't imagine ordering one little belt from any supplier ;)
    38459252820_4cdb0c0964_b.jpgDSC_6284_zps0d973208 by Mark Hardy, on Flickr
    The old, stretched belt is still "installed" in situ on the pulleys (even if way too stretched to do its job) in the photo above; the soon-to-be installed rubber band is in the foreground :) I use a dental pick to worry the new "belt" into place, appropriately enough :|
    If it's 'direct drive' (so to speak) -- my guess would be that the gears for the tray and/or the laser's sled tracks need to be cleaned/lubricated. I'll defer to others to comment on best practices for such activity.
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
  • Mr. SharpeMr. Sharpe Posts: 1,077
    Sounds good sir. I couldn’t tell ya if it’s direct or belt drive but dad told me if I can get it repaired easily he wanted it back haha i did open this unit and took the transport apart to bare bones where it was still spinning and i couldn’t tell much about it but will have to look again. Hopefully some folks with the same unit or one similar will chime in
    5 channel
    Sony Bravia 32" LED
    note that I used the term "direct drive" with extreme literary license :p
    If the tray doesn't use a belt, it's probably gear drive.
    Eh direct/gear hahaha I know what you mean
    5 channel
    Sony Bravia 32" LED
Howdy, Stranger!
