Inexpensive Desktop Amp
So I'm going in a different direction with the desktop setup and am looking for a small amp. I'm thinking something like the PS Audio Sprout but not wanting to spend that much money if I can avoid it. Its just powered a pair of Polk S15 so doesn't need much power, I just need something small and with a USB input.
Any ideas?
  • verbverb Posts: 2,559
    Dayens Ampino? :smile:
    2CH: Polk SDA 1C's, Micro Seiki MB14 TT, Rotel 1580 Pre, Marantz CD6006 CDP, Carver TX8 Tuner, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
  • LegenderLegender Posts: 443
    You mean something like this...
    http://www.audioadvisor.com/prodinfo.asp?number=NUDDA120&variation=SIL&gclid=EAIaIQobChMI6_TWkrWu2wIVSb7ACh3jXQa-EAQYASABEgL15vD_BwE
    Don't have one but looks pretty small and capable and might fit your needs.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
    A4L has this on sale. Yamaha WXA-50. They also have a small footprint Denon for sale, a bit more though.
  • AsSiMiLaTeDAsSiMiLaTeD Posts: 11,672
    verb wrote: »
    The Ampino a) lacks USB input and b) is too large for my use, too long
    Thanks for the other suggestions, I'll look into them
  • msgmsg Posts: 4,037
    edited May 30
    Are you using a sub as well, Danny, or just the S15s?
    Probably just the S15
  • DSkipDSkip Posts: 14,490
    No usb but the Vista spark is about half the height of the Ampino.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • ConradiclesConradicles Posts: 5,668
    Splurge and get the PS Audio Sprout. Looks like a perfect solution.
  • FestYboyFestYboy Posts: 2,317
    http://www.smsl-audio.com/productshow.asp?id=95
    I have one, it's small and has all the i/os you need
    How does it sound?
    Couldn't give you an accurate description as it is used in a super small room and with M4.6s for the time being. It's my girls studio rig. I should throw it on the kitchen rig for a comparison (using the 5JR+s so it would be close, speaker wise).
  • tratlifftratliff Posts: 602
    Danny take a look at the Teac products. They are great for desktops and have many features. Not the best for SQ but it really depends how you are looking to use it.
    Legacy Focus SE, McIntosh C50, McIntosh MC601's, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Marantz SA-14s1, Oppo BDP-105, Technics RS-1500, Furman Elite 15PFi, Douglas Connection Alpha Interconnects, Douglas Connection Alpha Speaker Cables, Pangea Power Cables
    Theater
    Yamaha RX-Z9, Legacy Focus SE (same as 2 Channel system), Def Tech C/L/R 2500, Def Tech BP-2X, Def Tech Pro-Monitors, Vizio M-75
    Office
    Teac NP-H750, Parasound Ztuner, Audio Engine P4N, Grado SR80, Grado iGrado, Audio-Technica ATH-M50, PC running High Rez files
    Living Room
    Yamaha YSP-4100 digital sound projector, Sharp Aquos 60"
    Bed Room
    Yamaha YSP-5100 digital sound projector, Sharp Aquos 70"
    WTH?? I posted that last night, not this morning.
    Please ignore the redundancy.
  • Mikey081057Mikey081057 Posts: 5,206
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A23 x2 Amps Parsound Halo A21 Amp & P5 Pre | Marantz SR5011 AVR | Usher Dancer Mini-x DMD's| Usher BE-616 Center|KEF T100 Surrounds | SVS SB2000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Bluesound Node 2 | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC |Samsung 50" SUHD TV
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node | Audioengine P4 | Peachtree Nova 125SE |
    Closet | SDA SRS 2.3's | Monitor 5B's Yamaha M80 | Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2385
  • ClipdatClipdat Posts: 3,467
    Stereophile liked it: https://www.stereophile.com/content/nad-d-3020-integrated-amplifier-sam-tellig
    Actually, the NAD is one that’s popped up a few times, anyone have experience with it?
    Got Dayens?
    In the end I think any of them will be fine with the S15. Maybe just find a feature set and call it a day.
    audiothesis.com/
    Cabling: Wireworld
  • IrrenhausIrrenhaus Posts: 730
    Did not check price
    http://audio.teac.com/product/ai-503/
    My 2cents
    Cheers
    AVR-Onkyo709
    AMP- Parasound 2125, Adcom 585
    Mains for HT and some Music- RTi12s
    Main for Music only- Linn Keilidh or Usher V-601 and SDA 1C
    PreAmp for Music: Cary AE-3
    Rear- RT150
    Center-CSi5
    Sub-Rythmik audio F25
    Player- Oppo BDP-103
    Bedroom rig:
    Pionner Elite VSX-30...Onkyo CS-5VL SACD Player....Polk Audio LS70
    Irrenhaus wrote: »
    Did not check price
    My 2cents
    Cheers
    Retails around a G new
  • dragon1952dragon1952 Posts: 4,363
    Grant Audio Tube DAC-11
    ____________________________
    2 channel - Parasound A21 amp, PS Audio DirectStream, Intona USB Isolator, Asus EEEBox running JRiver, Tom Tutay modded EE Minimax pre, Furman Elite 15 Pfi power conditioner, Martin Logan Electromotion ESL speakers, Kimber 4TC speaker wire, Gabriel Gold Reflection V2 IC's, VH Audio Flavor 4 x 2, Flavor 2 and Pepster power cords
    Computer - Windows 7/JRiver, Grant Fidelity TubeDac 11, Fostex PMO.4n monitors
  • mdaudioguymdaudioguy Posts: 4,357
    Anybody familiar with the Parasound Z line? Seems like it could be a nice option.
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
  • mpitogompitogo Posts: 249
    Not small but $399, integrated amp with USB input and lots of options.
    https://emotiva.com/collections/basx-series/products/ta-100
    Music-2.0 Raidho D-3.1 | Audio Research Ref 40 | Jeff Roland 925 | Esoteric Grandioso K1 | Transparent Reference, IC, Speaker and Power | HRS SXR Rack
Howdy, Stranger!
