Inexpensive Desktop Amp
So I'm going in a different direction with the desktop setup and am looking for a small amp. I'm thinking something like the PS Audio Sprout but not wanting to spend that much money if I can avoid it. Its just powered a pair of Polk S15 so doesn't need much power, I just need something small and with a USB input.
Any ideas?
  • verb
    verb Posts: 10,176
    Dayens Ampino? :smile:
  • Legender
    Legender Posts: 478
    You mean something like this...
    http://www.audioadvisor.com/prodinfo.asp?number=NUDDA120&variation=SIL&gclid=EAIaIQobChMI6_TWkrWu2wIVSb7ACh3jXQa-EAQYASABEgL15vD_BwE
    Don't have one but looks pretty small and capable and might fit your needs.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • verb
    verb Posts: 10,176
    A4L has this on sale. Yamaha WXA-50. They also have a small footprint Denon for sale, a bit more though.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,722
    verb wrote: »
    The Ampino a) lacks USB input and b) is too large for my use, too long
  • AsSiMiLaTeD
    Thanks for the other suggestions, I'll look into them
    msg Posts: 9,309
    edited May 2018
    Are you using a sub as well, Danny, or just the S15s?
  • AsSiMiLaTeD
    Probably just the S15
  • Conradicles
    Conradicles Posts: 6,010
    Splurge and get the PS Audio Sprout. Looks like a perfect solution.
  • FestYboy
    FestYboy Posts: 3,861
    http://www.smsl-audio.com/productshow.asp?id=95
    I have one, it's small and has all the i/os you need
  • AsSiMiLaTeD
    How does it sound?
  • FestYboy
    Couldn't give you an accurate description as it is used in a super small room and with M4.6s for the time being. It's my girls studio rig. I should throw it on the kitchen rig for a comparison (using the 5JR+s so it would be close, speaker wise).
  • tratliff
    tratliff Posts: 1,651
    Danny take a look at the Teac products. They are great for desktops and have many features. Not the best for SQ but it really depends how you are looking to use it.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, AudioQuest Thunderbird Speaker and Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • FestYboy
    WTH?? I posted that last night, not this morning.
    Please ignore the redundancy.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
    Clipdat Posts: 12,560
    Stereophile liked it: https://www.stereophile.com/content/nad-d-3020-integrated-amplifier-sam-tellig
    Actually, the NAD is one that’s popped up a few times, anyone have experience with it?
  • Irrenhaus
    Irrenhaus Posts: 1,082
    Did not check price
    http://audio.teac.com/product/ai-503/
    My 2cents
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Mikey081057
    Irrenhaus wrote: »
    Did not check price
    My 2cents
    Cheers
    Retails around a G new
  • dragon1952
    dragon1952 Posts: 4,894
    Grant Audio Tube DAC-11
    2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Anybody familiar with the Parasound Z line? Seems like it could be a nice option.
  • mpitogo
    mpitogo Posts: 475
    Not small but $399, integrated amp with USB input and lots of options.
    https://emotiva.com/collections/basx-series/products/ta-100
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
