Proper orientation of male split pin RCA plug
13»
  • afterburnt
    afterburnt Posts: 7,892
    mlistens03 wrote: »
    mlistens03 wrote: »
    Hey, I need your help, I can't figure out how to ignore @viking64. :wink::tongue:
    Congrats, you just joined the class clown and clipdik on my list. Shame, I thought you might turn out ok.....oh well.
    Apparently I’ve been ignored. I’m not quite sure what I did. Can someone enlighten me?
    I would tell you but I am pretending to ignore you.
    msg Posts: 9,493
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Wondering if someone can help shed some light on the proper orientation of a male RCA plug with a split pin, in regards to how to correctly insert it into a female RCA jack.
    I notice that with the split pin cables, that when I'm plugging them in and they rotate slightly, sometimes I can hear and feel what I'm guessing is the metal inside getting stuck on the split of the pin slightly. It makes a little twang sound, like it stuck for a second and then releases.
    Looking inside a female RCA jack, there appears to be a horizontal piece of metal. I'm guessing this is what makes contact with the male pin and transfers the signal.
    Now, in regards to the split pin, how should this be plugged in to make "proper" contact? If I plug it in so that the split is sitting exactly horizontal, then the horizontal metal inside the jack will actually get inserted inbetween the split tip! I can't imagine that is ideal..??
    If anyone has a diagram of what the inside of a female RCA jack looks like, maybe that would help. Or any insights from people who having experience using RCA interconnects with split pins. Thanks.
    The below image may help explain the issue you're having. The center contact is simply a "spear" that is designed to engage the pin of the male connector, then deflect slightly during insertion while still maintaining contact.
    Should be not an issue with a solid pin connector. Nice smooth rounded end.
    However with a split pin, you have a cut right down the middle of the pin, introducing essentially a "slot" with two sharp edges. Not smooth by any means. Not hard to imagine an orientation of the slot engaging the end of the spear! At that point, the spear may actually be partially engaged in the slot, and with a little twist you bend the spear out of the way, once out of the way, twang!, the spear comes back to it's normal position.
    Just a theory of course, would have to be verified via experimentation. FWIW.
    Clipdat Posts: 12,622
    edited May 2018
    Nice explanation, that's exactly what's occurring! Now I know why you get paid the big bucks!
    You can see the "U-shaped" piece of metal that I was trying to describe on the left hand female RCA jack above. Both the sides and the end of it are what can get caught in the split tip.
    So, it seems like the split tip cables would work best for higher quality RCA jacks that feature a full 360 degree cup for the tip to sit in, versus the cheaper/more common style that are on most gear.
    At this point the split tip seems like a bit of a marketing gimmick, imo.
  • mlistens03
    mlistens03 Posts: 2,767
    edited May 2018
    Is there a supposed reason for the split tip? I've only ever seen it and I thought it was some way to make the cables cheaper.
  • verb
    verb Posts: 10,176
    I'm not an expert, but I believe they're designed to mate with a better quality RCA jack (cylindrical IIRC) instead of the spear type. The spear type is about as inexpensive as it gets.
    The split types are designed to deflect themselves (spring loaded) upon insertion, to ensure good contact along the entire mating surfaces, and keep good retention.
    Here's some marketing gibberish I've found just now regarding split pins:
    Split Pin Technology Ensures a Secure Connection.
    split-tipped center pin to ensure a tight connection and flawless signal transfer.
    the split pin and collar gold-plated RCA's also maintain a robust signal path and longevity.
    Split center pin allows for superior signal transfer
    split tip center pin and segmented shield for maximum contact and reliability
  • mlistens03
    verb wrote: »
    Clipdat wrote: »
    nice idea, but it doesn't seem like a winner to me... basically, your paying more money for less material?
    nbrowser wrote: »
    Marketing lies at its best....
    definitely.
    tonyb Posts: 32,908
    nbrowser wrote: »
    Marketing BS at its best....
    Indeed....same people who wrote that probably also write for womens magazines. ;)
    tonyb Posts: 32,908
    Clipdat wrote: »
    However the issue/situation here is that for a cable that has some weight/body to it, when you plug one end in, and then attempt to run it to the other piece of gear you are connecting, the weight and bulk of the cable can actually inadvertently rotate the plug in the jack.
    How about....resting the plug inside the jack without inserting all the way, then when the other end is connected, and the weight of the cable settles....you push it in. That way no additional turning happens.
    pitdogg2 Posts: 24,624
    tonyb wrote: »
    Clipdat wrote: »
    Know it all!!!
  • motorhead43026
    motorhead43026 Posts: 3,892
    I have Anthem equipment. They advise against these types of connectors. In fact they say in the owners manual that they will not repair under warranty any jacks damaged by this type connector. The argument is these will snag causing damage too the jack internals.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • machone
    machone Posts: 1,483
    I think I need to go lay down........
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
