magnifi sound bar powers off after approx. 10 minutes, continually
had been unplug for days for carpet replacement.
Answers
  • mlistens03
    mlistens03 Posts: 2,767
    Does it work for the 10 minutes it’s on? Is it exactly 10 minutes?
    If it doesn’t work and it’s execatly 10 minutes I would contact customer service and see what they say. Depending on when you got it it should be under warranty and you can get it replaced if they can’t help you fix it.
