Inexpesive speaker cables that would improve on Furez home mades
I need some better cables for my old Ushers, was looking at Canare are they any good?
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • ClipdatClipdat Posts: 3,467
    I think @Joey_V had some Audioquest Type 4 for sale.
    Got Dayens?
  • JaybeezJaybeez Posts: 654
    Pretty sure he's keeping those
    Living Room (HT):Denon AVR X-3000 ; LSiM 703 ; LSiM 704C ; FXi4s ; Sub – Rhythmik F12SE
    2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Ascend Acoustics Sierra 2s ; Polk PSW 350 Sub
    "And these children that you spit on, as they try to change their worlds, are immune to your consultations. They're quite aware of what they're going through."
  • pitdogg2pitdogg2 Posts: 9,808
    afterburnt wrote: »
    I use Canare 4S11 I like it. It is nothing special but it works. Signal Cable ultra is two runs of 4s8 in a techflex jacket.
    You could hit up Joey he had some long runs of the Audioquest Type 4. well priced
  • marvda1marvda1 Posts: 2,982
    http://www.realitycables.com/
    while $310 for an 8 ft pair you can hold onto these up into the mega buck systems.
    these have been around for a long time, i still have mine.
    Amplifiers: MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800, Usher R1.5
    Transport/Dac: Cayin Venus cd-100i, Musical Paradise mp-d2 mkI
    Speakers: Rosso Fiorentino Volterra
    Speaker Cables: Analysis Plus Black Mesh Oval 9, Cerious Technologies Graphene Extreme
    Interconnects: Analysis Plus Copper Oval-In Micro, MG Audio Design Planus Cu2,
    Power Cables by: Cullen Cables, 6sons Audio, Swiss Cables
    Autoplay music on their website makes sure I'll never order from them.
    marvda1 wrote: »
    Got Dayens?
  • steveinazsteveinaz Posts: 18,201
    Also check Signal Cables offerings. Heck of a value.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; DH Labs D-75 | AC Power: Panamax M5300-PM
  • tonybtonyb Posts: 29,042
    edited March 21
    marvda1 wrote: »
    I'd second that suggestion. Though used you can find them for around 150 bucks for an 8ft pair.
    http://www.usaudiomart.com/details/649423903-gregg-straley-reality-cables-speaker-cables-7ft-red/
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    Clipdat wrote: »
    marvda1 wrote: »
    don't let that stop you from improving your system.
    Of course not. I already have some nice AQ Bedrock cables for my 2 channel setup.
    Been looking at Signal cable or Douglas Connection for some custom terminated cables for my computer rig.
    marvda1 wrote: »
    Got Dayens?
  • vmaxervmaxer Posts: 4,203
    edited March 21
    mistake
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DaveHoDaveHo Posts: 1,809
    Making speaker cables is easy. Figure out what the raw materials are on some of these suggestions & build your own. Raw material cost is probably less than half.
  • rpf65rpf65 Posts: 1,653
    afterburnt wrote: »
    What do you dislike about your current cables.
  • afterburntafterburnt Posts: 4,388
    @rpf65 I want to biwire and get rid of the jumpers also the bananas I have aint so good.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • delkaldelkal Posts: 214
    DaveHo wrote: »
    If you decide to go this route just buy the wire first, hook it up directly, and try them out on your system. This is the best they will sound.
    If they are compatible then spend the money on good terminations.
    I was looking at BJC's with their fancy welds
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    https://www.thecableco.com/cables/speaker-cables/4pr-biwire-speaker-cable-pair.html
    Pretty good and works well with a variety of equipment/speaker combinations.
    May also want to look into The Cable Company's lending library. Try different brands for minimal cost.
  • gudnoyezgudnoyez Posts: 6,158
    Audio Advisor has a pretty good deal on Audioquest type 4 and type 8 in their spring clearance catalog. If you don't want to biwire.
Howdy, Stranger!
