Question regarding bi-amping speakers per Polk manual.SDA SRS 2.3
bassfann
According to the original Polk literature, the 2.3 speakers do NOT need an electronic crossover,or even an ai-1 to biamp them. I know many feel different about it. What is the reason behind it.
You better read that again.Political Correctness'.........defined
President of Club Polk -
I use a common ground amp with 5 channels to bi amp mine. Has workwd for years. No external xover and no dreadnaught.Too much **** to list....
deleted
2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
Of course, you're not actually bi-amping.Political Correctness'.........defined
You better read that again.You better read that again.You better read that again.
You're generalizing things that shouldn't be and leaving out important information.
Yes, you can pseudo bi-amp those speakers, but it's not true bi-amping unless you use active crossovers. You can pseudo bi-amp any pair of speakers with two sets of binding posts.
This is the important information, "The low frequency amplifier must be common ground unless the AI-1 adaptor is used."
Post edited by [Deleted User] onPolitical Correctness'.........defined
Can I bi-wire without the ai-1 ? Reason I’m asking is I’m running a Bryston 8b 4 channel amp.
Can I bi-wire without the ai-1 ? Reason I’m asking is I’m running a Bryston 8b 4 channel amp.This is the important information, "The low frequency amplifier must be common ground unless the AI-1 adaptor is used."
^^^^ This....
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
If the amp is common ground, yes.
