Speaker jumper cables
So is replacing the stock plates on my S60 speakers with jumpers worth it or can I just use the same speaker wire and cut sections and connect these wire to wire without spades on the back speaker posts. Is there any real advantage to doing this.
«13
  • verb
    verb Posts: 10,176
    firsttimer wrote: »
    Hello @firsttimer generally the stock plates are inferior than jumpers you can buy from a lot of audio cable sellers. Lots of choices out there. I would research the many threads in CP on speaker cables. Lot's of voices on that subject.
    I would venture to say that if you're just replacing the stock plates with generic speaker wire (depending on what kind of wire you're currently running) - not much if any benefit.
    Again if you go down the cable rabbit hole, as I have done recently, plenty of choices with folks claiming many benefits.
    I just swapped out my home brew cables (10ga wire, soldered ends, bannans jacks) with a set of MITAvt's bought here on CP and immediately noticed an improvement. Most notably the bass response. I am now a cable believer!
  • gp4jesus
    gp4jesus Posts: 1,969
    Do you have any spare/leftover wire? Try it
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • firsttimer
    Yes I have left over wire so going to try it today maybe and see what happens. Should not take long to do it.
  • helipilotdoug
    Good copper wire is a much better jumper than the gold plated brass jumpers most manufacturers use. Try the wire and if you notice an improvement, then you might want to get yourself a set of jumpers. We can fix you up if you decide to go that way. :)
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • gidrah
    gidrah Posts: 3,049
    I usually use bare (no terminal) speaker wire. When I have speakers with bi-wire connections I approximate the length, add 1/2 inch, cut the sleeve, slide it up and leave enough for the other terminal. Use that space of bare wire to wrap around the other terminal.
    Make it Funky! :)
    F1nut Posts: 49,806
    Well, well, well....who left the door open? :p
  • verb
    verb Posts: 10,176
    Aren’t you being nice today? :wink:
  • firsttimer
    Ok so are there any jumper cables you would recommend that will not break the bank. North of the border so can order through eBay. Maze audio comes up nut not sure if those are any good. Looking for suggestions. Thanks
  • verb
    verb Posts: 10,176
    Ebay has a set of WireWorld Oasis jumpers right now for 75 bucks. I've run the Oasis IC cables in my rig. A decent upgrade IMO.
  • firsttimer
    Thanks will have a look
  • gp4jesus
    edited March 2018
    firsttimer wrote: »
    So is replacing the stock plates on my S60 speakers with jumpers worth it(?)
    yup
    firsttimer wrote: »
    can I just use the same speaker wire and cut sections and connect these without spades on the back speaker posts?
    YUP!! If you back out the red & black of the BPs, you’ll see a hole. A 6” piece 12 or 14 ga will do it. That’s all I did.
    firsttimer wrote: »
    Is there any real advantage to doing this?
    Doing the above? Yeah you’ll save $75!
  • firsttimer
    Well thanks for all your input I just put in a pair of audioquest silver jumpers. I must say there is a definite difference in sound quality I think bottom end and top end is more defined than before. Even midrange if that is possible. Time for a speaker wire up grade I see could be in my future lol if the jumpers did that can only imagine what a good set of audio quest speaker wires will do.
  • verb
    verb Posts: 10,176
    Lots of threads here on speaker cable. Hold on tight! :smiley:
  • firsttimer
    Yes I have been looking. I have a local store that I can by audio quest speaker cable from by the foot then attach banana plugs. We will see what happens lol
  • verb
    verb Posts: 10,176
    A pair of MIT terminator 4’s just popped up here on CP for sale. Smoking deal!
    F1nut Posts: 49,806
    There's also a nice pair of Audioquest speaker cables in the classifieds. Much better than the by the foot stuff.
  • firsttimer
    North of the border in Canada so need to look closer to home thanks though
  • firsttimer
    I can order audio quest type 4 speaker cable from an online Canadian vendor. 4 foot sections with the banana plugs. Is this good speaker wire
  • teekay0007
    teekay0007 Posts: 2,289
    firsttimer wrote: »
    I can order audio quest type 4 speaker cable...Is this good speaker wire
    I've been using those for a while and really like them, but that's just me talking.
    Joey_V just got some new ones in that huge FedEx shipment he posted on recently. And he's the kind of guy who spends $$$ on power cables. :o
  • Joey_V
    Joey_V Posts: 8,521
    Before you order, why don’t you PM me and see what you need from my little stash?
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • Joey_V
    Joey_V Posts: 8,521
    firsttimer wrote: »
    Well maybe you're enroute towards some silver AQ speaker wire... wink wink.
    F1nut Posts: 49,806
    firsttimer wrote: »
    Being south of the Canadian border never stopped me from buying anything in Canada.
  • rooftop59
    rooftop59 Posts: 7,981
    firsttimer wrote: »
    And I have sold several items here and on audiogon that went up north. Lots of folks here would be willing to ship at cost, and many cables you might find here can fit in a medium size USPS priority box...
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 32,906
    You have bi-wire cables by the looks of it, why did you order jumpers ? You don't need them.
  • gp4jesus
    edited March 2018
    @ Firsttimer:
    gp4jesus wrote: »
    firsttimer wrote: »
    Yes I have left over wire... ...[I’ll*] try it today maybe and see what happens.
    Did you get around to trying leftover wire?If so, better(?) Different? No change?
    Also those AQ jumpers, they just feed the mids & tweets, connected by the lower speaker BPs? In others words the existing wire between the woofers and the amp or AVR?
  • firsttimer
    I actually installed audio quest silver jumpers and have the normal speaker wire hooked up to the lower poles on the speakers. Doing this I have noticed a slight improvement in souls from kids and highs And highs. I have the S60’s crossed at 80 hertz using two Velodyne subs
  • gp4jesus
    edited March 2018
    @ Firsttimer:
    gp4jesus wrote: »
    firsttimer wrote: »
    Yes I have left over wire... ...[I’ll*] try it maybe and see what happens.
    Did you get around to trying leftover wire, BEFORE installing the AQ jumpers? If so, better(?) Different? No change? The existing wire between the woofers and the amp or AVR are the same when you started this thread?
    pitdogg2 Posts: 24,587
    firsttimer wrote: »
    Boy I'm confused
    F1nut Posts: 49,806
    A tad too high me thinks.
  • firsttimer
    firsttimer wrote: »
    Boy I'm confused
    I would be to lol. Improvements in mids and highs lol.
    No did not use speaker wire. I removed factory plates and installed the audio quest jumpers instead.
