Looking for a new amp.
My Adcom GFA-555 right channel has died and looking for a new amp. Will be powering a pair of LSi15’s with a Schiit Freya as a pre amp and Yggdrasil as Dac and a cheap turntable. I had a pair of Schiit Vidars on order but after a month did not ship so cancelled the order. I’ve got about $1500 to spend on the amp. Can’t be bigger than the Adcom as I have to take apart my table to get it out. I would like something on the warm side as Freya is a bit on the bright side but still looking at tube rolling just haven’t had the time .
  • ClipdatClipdat Posts: 4,236
    Shame about the production delays on the Vidars. I just checked their site and they're still quoting 10-15 days before shipping. I guess they continued taking orders during the delay and now they're probably back ordered. Too bad, as they would match aesthetically (and maybe audibly) with the other Schiit gear that you already have.
    Since your budget is pretty high, you might consider getting the amp serviced and upgraded from Big Sky Audio: http://bigskyaudiomt.com/index.php?pr=Audio
    Even after the full upgrade cost of $549 plus shipping both ways, you'd still be coming in well under budget, and giving new life to an amplifier that you're already familiar and (hopefully) happy with. Just something to consider.
    A well cared for used B&K might give you that warmth that you're looking for. I'll have to defer to others for used amp suggestions that have a warm tonal quality, as this isn't an area that I know a ton about.
    Regarding the Freya and tubes, keep us updated on what direction you end up going in! I just recently purchased the Saga and I'm starting a small collection of 6SN7 tubes myself.
    Got Dayens?
  • FestYboyFestYboy Posts: 2,528
    Used NAD M series?? Might take a little hunting to find one in your price range. Or one of their big boy Power Envelope amps... They should be the warm sound you're looking for.
  • mrbironmrbiron Posts: 4,787
    Order the Aleph in the flea market.
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
  • Buke9Buke9 Posts: 31
    Thanks for the replies. Nad is definitely on my list. Fixing the Adcom is a option hadn’t considered thanks for that and upgrading it in the process is also interesting.The Aleph looks like everyone loves it . Haven’t had much experience with power amps as mostly before just used receivers so this helps me get a idea of what is out there to look for. I’ve been more into headphones as of late so haven’t spent much time looking at 2ch stuff and all the decent shops have moved out and all we have is Best Buy Magnolia. If I find some smoother tubes for the Freya I’ll pass that on to you there is a pretty good discussion on Head-Fi on rolling the Freya.
    Thanks again.
  • gp4jesusgp4jesus Posts: 1,157
    Consider Big Sky audio in Montana. SteveB had his Adcom 585 "warmed over" there. Had raved to me many times "$ well spent!"
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
  • dhart86dhart86 Posts: 1,413
    Main Rig:
    HTPC (J River) > PS Audio Directstream Jr.>Rogue Audio Metis >McCormack DNA 0.5 Rev B
    Harbeth C7 ES3
    Second Rig:
    HTPC (J.River)> MF V-Link> Adcom GDA 600 > Cayin TA 30 (buzzy-bee mods)
    Monitor 5 (Westmassguy-modded)
    Someone has suggested Big Sky and that is for sure a option .
    Heard McCormack amps mentioned on another forum and yours looks to be in great condition as I’m not opposed to getting used as the Adcom was used.
    Have also been looking at some B&K amps as some are touting them to have a tube like sound and that is somewhat appealing to me . Have also found Stratos amp by Odyssey that also looks good but would take all the budget.
    Really appreciate the suggestions from all on this and anyone else feel free to add some more.
  • kharp1kharp1 Posts: 2,411
    edited January 30
    I'd take a serious look at the Usher that's currently for sale in the flea market. Marvin is a good guy, and, got a feeling it won't hang around too long. You hardly ever see them come up for sale.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
    Thanks will have a look see.
  • steveinazsteveinaz Posts: 18,269
    I'm taking a HARD look at the Parasound 2250v2. My HCA-1500 is 15+yrs old now.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; Belden 1694A Dig Coax | AC Power: Panamax M5300-PM
  • MrBuhlMrBuhl Posts: 2,308
    edited January 31
    dhart86 wrote: »
    Just IMO, for $770 you will be hard pressed to find a better amplifier than this one, and it's pretested by a long-time Polkie to not have any issues. I wouldn't call it warm, but it's not bright or clinical either, it's what Goldilocks referred to as "just right". Far under your budget, but better than any new amp you're going to get for $1500, again, in my humble opinion.
    VA 2 Channel ,Dodd 50W Dual Mono EL34 Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, Audioengine B1, MIT AVt3 Speaker & RCA Cables, PS Audio Power Punch power cables
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
    MrBuhl wrote: »
    dhart86 wrote: »
    I would have to agree and....thank you Mr. Buhl,
    however MY McCormack is no longer available
    Main Rig:
    Harbeth C7 ES3
    Second Rig:
  • bikerboybikerboy Posts: 1,136
    My pass Aleph would be a fine choice.
    D:Sonore UltraRendu usb w/LPS-1->Amanero I2S converter ->I2S->TPA Buffalo 9028 w Mercury output dac w Salas ps->BAT VK-51SE w/BP Preamp via XLR to BAT VK-200-> Polk LSiM 703
    A:Dynavector DV-10x5-> Nothingham Spacedeck-> TPA Retro via XLR to Relaixed2;
    V:Vinyl rips-> ESI [email protected]/192
    SACD: Denon 3910
  • JaybeezJaybeez Posts: 677
    I’m getting ready to sell a Plinius 9100.
    Living Room (HT):Denon AVR X-3000 ; LSiM 703 ; LSiM 704C ; FXi4s ; Sub – Rhythmik F12SE
    2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Ascend Acoustics Sierra 2s ; Rythmik F12SE
    "And these children that you spit on, as they try to change their worlds, are immune to your consultations. They're quite aware of what they're going through."
  • Mr_HzMr_Hz Posts: 132
    edited February 23
    I have a brand new Parasound 2250v2 275watt (8ohms) that I'm considering selling. Bought it a little quick, and then the Parasound Halo 21's went on sale. Would consider ~$900 + shipping +/-... haven't even cracked the box on this black unit. List is close to $1400, and AA was selling around $1k.
    If interested at all... PM me and let's see what we can work out as far as price + shipping. Again the amp hasn't even been taken out of the box, powered up. Recent purchase.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
Howdy, Stranger!
