VTL TL2.5 Tube pre amp
ipsullivan
in Electronics
I have been looking into adding a pre amp to my 2 channel setup. I like the idea of a tube pre amp combined with a solid state amp.
My current setup is a Marantz SR7005 and PS Audio 200C power amp. They are feeding fully modded RTA 11t’s.
I found a VTL 2.5TL for sale somewhat locally, it appears to be in good shape. Have yet to audition it. After some
light searching of the web it seems to be a solid choice.
Does anyone have any experience with this pre amp? Any clue to how this would benefit my ears?
Asking price is just shy of $1,000. Is there other/better options in this price range?
Thanks,
Ian
Thanks,
Ian
Your sound stage will grow like you won't believe.
Joule Electra is an excellent choice.Political Correctness'.........defined
President of Club Polk -
I'll second F1NUT's comment, you may want to search out some nos tubes for it too in case the ones in there are junk or bad. Brent Jesse would be a good place to start.HT SYSTEM-
lsi 9's -
I had the VTL 2.5 pre many years ago and I wouldn’t hesitate to recommend picking one up.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
using one now, highly recommend VTL..
ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
I'd say anytime you can find a Joule/VTL/VAC PRE under a grand....run...don't walk.HT SYSTEM-
