Adding Atmos Speakers??
Toolfan66
Toolfan66 Posts: 16,952
edited January 2018 in Speakers
Thinking about the 900-LS or 700-LS but is it worth all the work and $$$$ Let alone cutting a hole in the ceiling...
I also thought about hanging my LSiM 703's above my 707's...
Thoughts???
    txcoastal1 Posts: 13,134
  • sgmsmg
    sgmsmg Posts: 542
    I have 900-LS speakers for Atmos and enjoy them. The house I purchased already had cheap in ceiling speakers so I just upgraded them. They are not ideally located but they definitely add to the dimensionality of the sound. At some point I need to run better cable to them to replace the builder spec stuff.
    I don't think hanging 703's above the 707's would achieve the same results. They would be more like adding height speakers where Atmos speakers are supposed to be either firing down or reflecting off the ceiling. I am sure the 703 height speakers would add to the experience but it may not be ideal.
    The cutting a hole in the ceiling isn't a big deal breaker as long as you have access to run speaker cable to them without tearing apart your walls.
    If I were starting over and didn't have large holes already in my ceiling I think 700-LS would be more than adequate for Atmos duty. Most of the sound directed to those channels is greater than 100hz so you don't need a speaker that digs into the lower frequency range.
    This is all just my $0.02 based on my experience and the limited research I have done.
    Good luck!
    Pre:Bryston BP173
    Amp:Bryston 14B3
    Speakers: Golden Ear Triton Reference
    Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90/JBL SDP-55
    Amps: Parasound A31, A51x2
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    Thanks for the info guys..
  • dolbyd
    dolbyd Posts: 430
    I run 2-700LS in the MB LSI system and 4-70RT's in the main room rig. Both are great speakers for Atmos and Surround duty.
    Make sure you have room they are deep. I have seen issues with fitting them on a 2 story home with shallow ceilings.
    Love the magnetic grills too.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • teamjhertz
    teamjhertz Posts: 361
    edited January 2018
    I am pretty pleased with 4 50RTs for surround duty as well. Even these small ones were rather deep and barely fit in my basement ceiling
