Lost in space of audio
  • Viking64Viking64 Posts: 3,083
    Space is kind of a problem it’s a rather small apartment
    I started playing with the Yamaha eq settings and went up with the highs and lows 2db
    Anyone has experience with a good set up for this speakers and a Yamaha receiver ?
    The center kind of clears the tv. It is the S35
    I guess that’s why is so slim
    Thanks for the help
    Yeah, on closer inspection, I can see things are pretty tight. Especially in the corner by the window.
    Perhaps you could move that ficus tree a little closer to the window. That might allow you to do what F1nut suggested as far as moving the mains out and toeing them in more. (Which would "kick" the backs of the speakers a little more outward.)
    Try to put the inside front of the left speaker as close to the front corner of the TV "stand", angling as much as space allows. Then just set the other side to match. It might not be the most ideal sound-wise, but it should be a definite improvement over how things are now.
    I would like to say "Put the tree ON the subwoofer so it isn't in front of the left tweeter", but I don't want to start any trouble. :p
  • F1nutF1nut Posts: 40,195
    Thanks for the help
    The optimal set up will vary from system to system and room to room. Use the calibration program to set a base line then tweak to your liking from there.
  • TNTsTunesTNTsTunes Posts: 754
    I would want the center channel speaker closer to the front edge of the TV stand so the sound doesn't have to reflect off of the stand as soon as it leaves the speaker, but that's just me...
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • TNTsTunes wrote: »
    Sadly it doesn’t fit beneath
  • Any ideas where the headaches with the systems comes from
    I mean too much treble ?
    Too much bass?
    Too much controls to tweak? Lol
    TNTsTunes wrote: »
    Will it fit in front of the TV without blocking the screen?
    TNTsTunes wrote: »
    Good idea
    Function before form
    edited January 5
    There ya go. Now pull the mains out a bit and toe them in slightly. You might also want to try angling the center up slightly.
    ^^^^^ Agreed.
    It still looks good too.
  • txcoastal1txcoastal1 Posts: 9,874
    Love your room and your setup. I know you are bound with aesthetics and WAF.
    When you get some alone time you really need to pull those speakers out at least 3"-4" (preferably 6") in front of that cabinets and play with toe'ing in the speakers.
    We just want you to experience that moment where you get true stereo imaging and sound stage. When you do this set your receiver in "pure direct" or 2 channel only using your speakers. You'll sit in the sweet spot.
    It will make the difference of between just listening to music...vs really hearing the music as intended/recorded with "stereo"
    This will enable you to understand what and why we have critiqued your system...which is really nice. Understandably you may not me able to leave it this way 24/7, but you will see what it can produce and what it was designed for and help you tweek the system.
    Google up any terms I have posted that you don't understand...you'll thank us later
    ---Cheers
    Welcome to Club Polk
  • txcoastal1 wrote: »
    ---Cheers
    Wow everything made a difference
    I toed the speakers and the center has more presence
    Now with a low volume sounds better
    Already google some terms lol English is not my native language
    Very rich sound
    Not muddy as my previous previous Sony speakers
    My previous Polk r150 were awesome
    This signatures have a richer dynamic tonality
    I’m thinking in using the R150 as back speakers and making a 7.1 system
    What do you think?
    edited January 5
    Soundstage – Described in 3 dimensional terms (height width and depth)
    Imaging – The placement and position of an instrument as interpreted through the use of a product....singer usually up front and instruments projected as if you were watching live...also falls back to soundstage terminology
    WAF---If you're married, "Wife Approval Factor"
    If the wife is not happy, she will make sure no one is happy ;)
    So what is your native language if you don't mind sharing
    Enjoy
  • I’m from El Salvador and my wife hates high volume lol
    I guess most wives does
    First our mothers then our wives lol
    We men are cursed for life
    I watch movies with my thumb on the remote control lol
    Yes sir, :D :D :D but if you can demonstrate how good it sounds
    We sometimes can get a smile and a little approval out of them...then back to work to buy them a pair of shoes or a new purse ;)
    Good luck and let us know as get become one with your music system
    Congratulations and enjoy
  • afterburntafterburnt Posts: 4,428
    Nice set up, too bad it cracked your table. BTW you type English better than me.
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • Hey guys
    For the first time in a long time I just sat to listen to music again
    It is really awesome
    This system is great
    A friend of mine has the Kplish reference system and I didn’t like the highs tonality
    Too bright for me
    Another friend has the electrostatic Martin Logan and for me were too bright without presence
    I decided to buy Polk cause the R150 bookshelf speakers I have were perfectly balanced for my ears
    At the end we all are different
    I just love how Polk audio sounds for a good price
    Bet you were smiling ear to ear. B)
  • Hello
    After my initial excitement
    I’m starting to see some issues
    The thing is that I have two doubts or complaints
    1. I feel the system has more highs and bass but lacks mids and
    2. I feel that to get a decent sound I need to crank it up a little bit
    My system is definitely better than my old Sony receiver with two Polks R150 in that I gained clarity, more details, more dynamic range but I lost the fullness of the sound
    Trying to describe it
    before it was ||||||||||||||||||||||||||| now it is |||||||:::......||||||,,,,,,,|||||||||||
    I played a lot with the auto eq with a post refined tuning but still not a sound as a i would dream of. I liked the tonality of the R150 better. What can I do?
    Maybe my ear is not used to good quality sound lol
    Which Yamaha AVR did you buy?
  • F1nut wrote: »
    The Yamaha rx 683
    I had the Sony str 820
  • Sorry for bothering everybody
    I’m posting my mistake normally in the Eq i use bass +5 mid -2 treble +5 and I was doing that in this system and the backs and surrounds were flat
    I set the eq with 3 slopes including mids and now sounds robust and full
    Thank you for all the tips I received here
    All were taken into account and now this system sounds how I like it
    Thanks again.
Howdy, Stranger!
