SVS B4+ purchase - yay or nay
brettw22brettw22 Posts: 7,682
I have the possibility of buying an SVS B4+ from circa 2003 and wanted to reach out and see if any of y'all ever had extended listening time with that.
I've read some of the posts on here from 2003ish, but I wanted to see what y'all thought about adding that to the mix......
  • F1nutF1nut Posts: 38,512
    It appears to be a passive sub, so you'd need an amp to drive it. Other than that, I think their newer subs are more advanced and come with a built in amp.
  • Joey_VJoey_V Posts: 5,761
    That was my dream sub for so long
    Joey's Gear:
    Current Gear:
    Emm Labs DAC2x and TSDX Transport -> Cary SLP-05 preamp -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature B) ) -> new speakers -> :D
    Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3 -> :o
    Rotel RC1570 preamp -> Rotel RB1582 amp -> B&W PM1 -> o:)
    Old Gear:
    Speakers: Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
    Source: Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
    Preamplification: Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased)
    Amplification: HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
    Subwoofer: Infinity Entra2 sub -> SVS 25-31PC+ sub
  • EmlynEmlyn Posts: 1,941
    I would say “maybe” depending on what else would be in the mix, including the size of the listening room and the oberall objective.
    May be worth reaching out to Ed Mullen at SVS to see what he thinks. For the price of a used one plus a high output pro amp you could find something new and more suited to what you are looking at achieving.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Parasound A21; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • brettw22brettw22 Posts: 7,682
    edited January 1
    With a separate amp, sub, and shipping it would be about $1500ish........the end table sized B4+ is a behemoth that might be too hard to resist implementing.
    It is massive overkill (aren't they all), for what I would 'need' it for, but it would be fun to have......also might be fun to shatter a window or two if necessary to up the fun factor......
    The only qualm I have about the one I'm looking at is it's the lighter maple, so I may plan on sanding/refinishing it to a darker stain......
  • DaveHoDaveHo Posts: 1,596
    In a way, the sub being passive could be a bit of a plus since you need not worry about the condition of amp caps & the like. I have it's little brother, the Plus/2 with the 12.3 drivers. I've never found its limit. The one you're looking at is a monster, LOL.
    brettw22 wrote: »
    For $1500 you can get the new SB-4000. Looks better, has remote control and should perform better.
    Watching the videos on that right now.......i have glimpses of rationality every once in a while, ya know.....
    Of course, you do....
    Ed was unavailable when I called, but the guy I spoke with said that in order for me to get the same umph as the B4+ I would need two PB13's or 4000's...........tempting tempting tempting......
  • IrrenhausIrrenhaus Posts: 700
    Or for about the same price get an F25 from Rythmik. Just my 2 cents.
    Cheers
    AVR-Onkyo709
    AMP- Parasound 2125, Adcom 585
    Mains for HT and some Music- RTi12s
    Main for Music only- Linn Keilidh or Usher V-601 and SDA 1C
    PreAmp for Music: Cary AE-3
    Rear- RT150
    Center-CSi5
    Sub-Rythmik audio F25
    Player- Oppo BDP-103
    Bedroom rig:
    Pionner Elite VSX-30...Onkyo CS-5VL SACD Player....Polk Audio LS70
  • Airplay355Airplay355 Posts: 4,072
    I vote for something newer. Curious though, what amp were you going to power that monster with?
  • VR3VR3 Posts: 21,848
    The B4 is a monster... Im not so sure SVS makes anything that would directly compare anymore.. :open_mouth:
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    Airplay355 wrote: »
    Some sort of Crown 2000-2500w thing.....the guy has as K1 or K2, but I'd want something newer.
    I’m using a crown and love it. It’s way too much though (the sub and amp combo). I’ve got it turned down a good bit and keep it off for music. That b4 looks like it would be insane amounts of bass.
    B4 hits 120db at 20hz iirc
    Joey's Gear:
    Current Gear:
    Old Gear:
Howdy, Stranger!
