Polk Magnifi Mini HDMI ARC Not Working
I have a 2017 Samsung UN55MU9000 tv with a HDMI ARC port, but when I connect the Magnifi Mini through that connection it doesn't read the speaker. It worked for a minute or two when I first powered on the speaker but now it doesn't work at all. Any suggestions?
  • mdaudioguymdaudioguy Posts: 4,405
    Make sure you connect the Mini to your WiFi in order to get the latest updates. Make sure ARC is enabled on the Samsung. It should work by default, however.
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
  • berndoberndo Posts: 2
    I am having a similar issue with the HDMI ARC where I have to unplug the HDMI cable every time I turn on the unit or sound is not produced. How do you connect to wifi..don't see anywhere for a username/pword
    berndo wrote: »
    Download the Google Home app to connect to the Mini.
    for some reason unit won't play a sound unless you unplug the HDMI plug and plug back in. I did download the google home app and connected the mini thank you
  • vcwatkinsvcwatkins Posts: 1,647
    My (non-ARC) problems cleared up after attaching to network via ethernet and bringing up Google Home. IIRC, the firmware update automatically downloaded (v20), but it wasn't until some time later (overnight) that play was issue-free. I'm guessing it needed some downtime to reboot since (I'm fairly sure) I was not given a choice to reboot in Google Home. The Mini has remained attached since the update.
    Not sure if it's the case here, but in my experience, most (AV pre pro) HDMI handshake problems have cleared up with firmware updates.
    Den: Rega RP6 (mods) * AT33PTGII * Parks Budgie SUT * Jolida jd9 (mods) * Roon (Sonic Transporter) * Sonore UltraRendu (LPS-1) * Wireworld Plat7 * isoRegen (LPS-1) * Lush usb * PS Audio DirectStream Jr. * Joule-Electra LA-100 iii * Sunfire Sig II * PSAudio p3 * MIT S3 * Polk SRS 1.2 (mods)
    Office Rip: Music Hall MMF5.1se * Speed Box II * DL103r * Lounge Copla SUT * PS Audio NPC * Roon * Bryston bdp-1, Bryston bda-1 * Rogue Cronus Magnum ii * PSA Dectet * MIT s3 * LSA-1 Statement
    Beach: MH mmf2.1 * Denon dl-110 * Belles Phono 20a * Sonos * Chord QuteEX (Pardo PS) * Belles 20a * Pass Aleph 30 * PSAudio Dectet * MIT s3 * Polk SRS 2.3tl (mods) - Revel M22
  • fpenguinfpenguin Posts: 1
    edited July 2017
    Same issue here. HDMI Arc has been working flawlessly for many months with my Samsung UN55J6300, but all of a sudden it stopped working since last week.
    I have the latest firmware of Samsung v1500 and Google Cast firmware v20. Tried a lot of different settings but still haven't figured out how to get HDMI ARC back.
    The situation is a bit peculiar.
    When the Polk Mini is turned off, clicking on Volume buttons from my AppleTV remote will adjust the TV volume. As soon as Polk Mini is turned on, AppleTV remote will adjust Polk Mini volumn, but the sound will still come from the TV speakers.
    Having the Samsung Aninet+ setting On, and changing the Speaker List to HDMI does not help.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,463
    I'll send this to Polk CS.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • guyrabguyrab Posts: 6
    I just got my polk mini Magnifi, audio quality is great, everything works via the optical connection, google cast, bluetooth. I cannot get my ARC HDMI to work (and this is how I need the polk to work through). as i said everything works via the optical (so handshake with my LG SJ850 SUPER UHD TV works via optical). but I cannot get my ARC to work... the ARC does work with other devices so the TV is not the problem.
    I tried disconnecting and connecting a million times doesn't help. i got it to work after 50 times for 20 minutes via ARC, but that's that. any ideas?
    I read there is also the matter of FW. how do i upgrade the firmware on the polk? I just attached it via the ethernet cable to my network.... maybe this is going to solve something..... any help will be appreciated.
  • Same problem here about the ARC that is not turning on the sound bar.. Only after reconnecting the hdmi cable...
    Cam someone please give a solution to that?
  • Similiar problems to guyrab. HDMI ARC worked initially when LG TV was first turned on. To get it to work subsequently had to go into settings-sound and change output to external speakers every time TV was turned on- very annoying! I tried optical cable and that didn't work either. Later I downloaded Google Home and optical cable worked when tv was turned on, but not HDMI ARC. But I want optical connection free for Blu-ray player. Any thoughts on how to get HDMI ARC to work?
  • We have LG TV. HDMI ARC has been flaky. Just connected mini to wifi and got latest software. We will see if this resolves issue. To get it to work initially, we had to turn on Sound Out and turn on Simplink. It seems to work fine until we turn everything off. Had to disconnect/reconnect hdmi cable on mini to get it working again today.
  • @kmartin1125 having the same problem with my new LG TV.. annoying that it doesn't work without having to unplug and plug the HDMI back in..
  • OK...updated software on mini yesterday. After TV and mini powered off overnight, we had the same result of it not working without reseating the hdmi cable on the mini. Hopefully this little annoyance gets resolved soon.
  • BobbyVPBobbyVP Posts: 6
    Will these HDMI ARC issues with Magnifi Mini ever get fixed?
Howdy, Stranger!
