A Comparison Of Ten Digital Versions Of Kind Of Blue
DarqueKnight
DarqueKnight Posts: 6,765
edited November 2017 in Music & Movies
Introduction
Figure 1. Arguably the best jazz trumpet recording ever.
This is a follow up to my December 2015 report on a comparison of digital and vinyl versions of Miles Davis' "Kind Of Blue". The prior report is here:
http://forum.polkaudio.com/discussion/comment/2268611
Now, ten digital file versions of KoB are compared:
1. A 44.1 k/16 bit FLAC file derived from the Columbia/Legacy CD.
2. A DSD64 upsampled file derived from the 44.1/16Columbia/Legacy version FLAC file.
3. A 44.1 k/16 bit FLAC file derived from the Mobile Fidelity CD.
4. A DSD64 upsampled file derived from the Mobile Fidelity version 44.1/16 FLAC file
5. A commercially produced Columbia/Legacy 192 k/24 bit FLAC version purchased via download.
6. A DSD64 upsampled file derived from the Columbia/Legacy 192k/24 FLAC file.
7. A DSD64 rip of the Columbia Legacy SACD.
8. A DSD64 rip of the Mobile Fidelity SACD.
9. A DSD64 rip of the Mobile Fidelity 2 LP 45 RPM vinyl set.
10. A DSD64 rip of the Classic Records 4 LP 45 RPM vinyl set.
DSD64 file format is DSF.
The Columbia/Legacy CD, Columbia Legacy SACD, and Columbia/Legacy 192k/24 download were all remastered by Mark Wilder from the same source tapes.
FLAC rips from CD were made using dBPoweramp CD Ripper software, versions R15.1 and R15.3.
FLAC to DSD conversions were made using JRiver Media Center software version 20.0.131.
DSD64 rips from vinyl were made using VinylStudio software version 8.2.2 and a PS Audio NuWave Phono Converter analog to digital converter.
SACD rips were made using a modified Sony PlayStation3.
Fake News
A question that often comes up in discussions of digital upsampling is "how can upsampling sound better since no new information from the original recording is added?" The answer is that the upsampling algorithm makes a mathematical "guess" (interpolates) about the values of the missing samples. Depending on the quality of the recording and design and quality of the upsampling filter, the interpolated samples can result in a smoother audio presentation.
Another important point is that Direct Stream Digital (DSD) is not a "higher rate version of Pulse Code Modulation (PCM)". DSD is a completely different digital encoding scheme where information is encoded in electrical pulses of the same amplitude (1 bit), but the pulses have varying energy density. DSD is pulse density modulation. PCM (FLAC, wav, mp3, etc.) encodes information in evenly spaced electrical pulses of varying amplitude, where the maximum amplitude of a pulse is determined by the number of bits provided to each sample by the encoder. A 16 bit encoder produces samples that have 2^16 =65,536 possible amplitude values.
The original 16 bit PCM scheme developed for CD's was never intended to be a high fidelity encoding medium. The commercial goal in the mid 1980's was to produce an economical, durable, and portable alternative to cassette tapes and vinyl records. Conversely, DSD was designed to be an archival medium for analog master tapes, vinyl records, and other high quality, high fidelity analog media.
Results
Again, the list of file versions/formats is below. A single song from KoB, "So What", was used for all comparisons:
2 had more depth, more space around sound images and heavier images than 1.
4>2>3>1 with regard to depth, space around sound images, and image weight.
5>4>2>3>1with regard to depth, space around sound images, and image weight.
6>5>4>2>3>1with regard to depth, space around sound images, and image weight. The DSD conversion of the 192k/24 FLAC file exhibited some of the ambient information that I had only heard previously with the Classic Records and Mobile Fidelity vinyl versions and their DSD rips.
The 192k download version beat both of the SACD versions, therefore:
6>5>8>7>4>2>3>1.
To my delight, the DSD64 rip of Mobile Fidelity's 2 LP 45 RPM set sounded better than the vinyl. Further discussion is in my Turntable Retirement thread:
http://forum.polkaudio.com/discussion/comment/2268945
The DSD rip of the Classic Records 4 LP 45 RPM set was gladiator prime, therefore:
10>9>6>5>8>7>4>2>3>1.
Figure 2. Versions 10, 9, 6, and 5 provided a sense of sitting at the rear of the recording room. I could hear ambient reflections behind the middle of the chairs on either side of the listening seat.
Associated Equipment
Bryston BDP-2 digital player
dCS Debussy DAC
dCS Puccini U-Clock word clock
PS Audio PowerBase isolation platforms for BDP-2, Debussy DAC and Puccini U-Clock
Black Diamond Racing isolation Pits and Mk IV Cones
Pass Labs XP-30 line level preamplifier
Pass Labs X600.5 monoblock power amplifiers
Revelation Audio Labs Prophecy Cryo-Silver Split Configuration USB cable
Revelation Audio Labs Prophecy Cryo-Silver AES coaxial cable
Revelation Audio Labs Passage Cryo-Silver DB-25 power umbilicals for XP30 and XP-25 preamps
AudioQuest Sky XLR interconnects
AudioQuest Everest speaker cables
PS Audio PerfectWave AC-12 power cords
PS Audio PerfectWave P-10 AC Regenerator
Polk Audio SDA SRS 1.2TL loudspeakers (heavily modified)
Salamander Synergy Triple 30 audio credenza
    treitz3 Posts: 18,341
    Let's face it. Great music, horrible recording......regardless of format.
  • DarqueKnight
    Why does the recording sound horrible to you?
    There are 282 versions of this album (not counting digital download media). So, I don't doubt that some of them sound "horrible". However, I would not place that descriptor on the relatively few versions that I own.
    Old. Noisy. No clarity. Little micro and macro dynamics. Very little realism. Overall, just a bad recording. Limited in so many aspects.
    Not as bad as Adele but not too far off on the whole scheme of things.
  • mikeyb128
    mikeyb128 Posts: 2,885
    ^^ kind of surprised by this as well. I’m not in love with KoB but I did buy it on vinyl, a remastered version, just to see what all the hype is about. It is a remastered version by legacy vinyl, it is remarkably quiet, and really does sound very good. Anything I’ve bought by legacy vinyl is top notch quality.
    2 channel:
    Theater:
  • keenears
    I love having the different versions play the same song on my digital walkman through my tube amp, onto my IER-Z1R to hear all the differences in mastering and sound quality. Wow! I think # 10 on this list, the winner, is the only version I can't find anyway as a ripped digital download. It's a ghost. I would love for someone to prove me wrong ;)
