Bens Silver IC’s
Toolfan66
How long are the RCAs? And is this price for the lot? I don’t need no stinking balanced cables lol...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Might be interested in some stinking balanced cables. ??
My amp does balanced and unbalanced. Sadly, I'm zero percent aware of the advantages and disadvantages of going balanced.
teekay0007 wrote: »My amp does balanced and unbalanced. Sadly, I'm zero percent aware of the advantages and disadvantages of going balanced.
Please tell us you're kidding.... -
Bens cables are worth 3x/4x what Larry's posting. One thing I don't flip is cables. Cables are the ultimate tuner if you are one who switches gear.
One rig or component to the next, you'll never know if you have found your huckleberry2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
No...go ahead smarty pants. What's so great about balanced interconnects?
Balanced cables inherently cancel any induced noise from outside sources like EMI by carrying 2 identical signals, but having one inverted at the source, which is inverted back at the receiving equipment. Any noise that is picked up along the way is also inverted at the receiver on that one signal line and is cancelled out.
Unbalanced lines can't do that.
http://www.aviom.com/blog/balanced-vs-unbalanced/ this has visuals and more in depth explanation. -
I once watched Ben twist a set of balanced silvers...by hand..
As eccentric as he was.....he gave a lot of thought into every aspect of every detail. Be it cable design or frankenpolk speakers...... you will own a part of a persons respect of music. -
These are no longer for sale..
