Omni A1 amp
Dranon
I have it in my living room withe tv connected to aux in. First question when I use the A1 for music there does not seem to be anyway to switch the input to aux other then physically pressing the button on the unit. There does not seem to be a way to do this on the app. Also when it is on aux input there does not seem to be a way to adjust volume from the app either. I need to get up and adjust the volume on th A1 itself. It would be really nice to have this ability from the app. Every time I try to adjust the volume the A1 goes back to streaming instead of aux.
Hello,
Welcome! I'll try and find an answer for you.
Cheers, Ken -
Here's the answer:
"These adjustments are possible from the Polk Utility app. He can select the source and change the volume from there."
Regards, Ken
