Center Speakers
Currently using Polk CS10 for my center speaker. Would a CS245 be a downgrade or upgrade?
  • mrloren
    mrloren Posts: 2,456
    Don't think it would be much either way. CS10 is a newer model. What are your other speakers? What AVR are you using?
  • tenbow
    tenbow Posts: 3
    Sony Str dn1040
  • mrloren
    edited August 2017
    I would stick with the CS10. If you want to move up next would be the Signature S30 or TSX250C. I have both and find them very good center speakers. RTi line centers need to be matched with RTi speakers. I sold my CSi5 which is a monster center but it didn't blend very well with my Signature S60 towers.
    For a center speaker it is best to find a good match to your main L/R speakers.
    What are your L/R speakers?
    do you have a sub in the mix?
