RT800I crossover
I bought these towers about 8 months ago and just got around to hooking them up. Notice no working tweeter on one tower. Found a bad cross over. Does anyone know where I can source one at?
    txcoastal1 Posts: 13,132
    If Polk doesn't support it
    Post a pic of it and more than likely we can help you get it fixed or you van fix yourself
    Can you see any burned up stuff like a white block looking thing...(sandcast resistor)
    Don't see anything terribly nasty, are you sure it the xover?
    Reason I ask, is the whole speaker not putting out signal, or maybe just a driver/tweeter
  • Topher0384
    Drivers are fine, put the tweeter in the other power and it works fine. If i put the input from the amp in the out put part of the tweeter it works. But once I hook it up to the wire terminals I get nothings.
    Polk may still support replacement xovers, but if not post back and leave their response. Maybe someone has parts or speakers to let go to get them back up and running.
    Call Polk Customer service vs emailing them.
    You can search hifi shark to see if any for sale on the cheap
    Sorry couldn't help
