Help me build a 2 way speaker
EndersShadow
EndersShadow Posts: 17,542
edited May 2017 in Speakers
So I won a pair of beautiful horns at LSAF this year. Now I'm trying to put them to use and build out a speaker based on them.
At LSAF after some discussion with a couple folks, Russ Gates being one, we talked about doing a simple 2 way speaker. I can't do a corner loaded horn in my room as I don’t have 2 true corners.
I consulted with Wayne of PI Speakers (who made the horn) and he suggested two tweeters and two midrange/bass drivers to use, a B&C DE250 or JBL 2426H on the tweeter horn, and a JBL 2226H 15” or Eminence Definimax 4012HO 12” midwoofer.
I honestly can't see myself affording the JBL's as they would be about 2k in drivers alone, and I was hoping to get away with even a 10" midrange driver, but dont know how to spec out what would work best. The B&C and Eminence drivers will run about 600 for 2 of each and fit the bill and my wallet a bit better. Additionally I wanted to try and keep the midbox as small as possible while still playing decently low.
I also like that the Eminence driver has some suggested boxes already thrown together for you, but I'm not sure if their largest vented box (2.5 cubic feet if I'm reading right) digs deep enough for music as it starts to drop off around 45hz.
I can tell you I do really like the efficiency of the drivers as the Eminence mid is 96db and the B&C tweeter is around 110db. Means a small little tube amp/integrated is very possible.
These will be used with a sub, but long term I'd like the option of running them without one and getting them to play all the frequencies of most regular music (excluding my 20hz dubstep stuff).
So what I'm needing help with is this:
- What size box should I be using for my midrange/bass driver.
- What configuration should I use regular vented, bandpass or sealed (guessing vented of some sort but not 100% sure)
- How the heck do I design a crossover for these? Should I use a MiniDSP 2x4 and go fully active
- Am I going to be looking at a 4 or 16 ohm load on them given both drivers are 8 ohm
I'm beyond outside my wheelhouse here so looking for some advice.
Looking forward to starting to get this project to move forward and hopefully result in something cool.
Tagging some folks who know a bit about speaker building and horns....
@mhardy6647 @RuSsMaN @Wardsweb
Post edited by EndersShadow on
    mhardy6647 Posts: 33,068
    edited May 2017
    Yes, a new recruit to the dark side - the force is strong with this one :)
    So -- tell me more about the horns in question? What is their cutoff? Are they CD horns (i.e., do they require EQ)? What size are their throats (1", 1.4", 2")? What driver mounting configuration(s) will they accept? (screw on, Altec 2-bolt, JBL 3-bolt, Altec 3-bolt, JBL 4-bolt etc.)?
    Remember that you can use a high sensitivity driver and pad it down to match a lower sensitivity (ahem, cheaper) woofer if necessary :)
    My guess is you'll want a woofer with good (relatively speaking) HF extension, and cross in the treble horn as low as practical (which will depend on the driver & the horn) -- you said you want a two-way, yes?
    I will read your post carefully -- I wasn't able to force myself to concentrate (yet) on the information in there... but I shall :)
    There is much fun to be had!
    32398308763_320b6b8a8f_b.jpgDSC_7248 by Mark Hardy, on Flickr
    edited May 2017
    Crossovers :)
    There is a lot to be said for active XOs (modern or vintage) and biamplification -- but you don't have to start there!
    I cannot throw stones at DSP -- I know folks with (ultra) high-sensitivity systems who use it to good effect; but (personally) I like simple. Sort of like Warren Buffett ;) I tend to avoid technologies that I cannot actually understand myself.
    I am thus, not surprisingly, something of a crossover Luddite -- my opinion was (and is) that simple first-order XOs (on the treble driver, or both drives, depending) are a good place to start. A treble driver that is more sensitive than the woofer is a "plus" here, I'd opine, since a variable L-pad can be used to dial in the HF response to be either as flat as possible (measured) or as pleasant as possible (by ear).
    33079486532_ca3cfdaee1_b.jpgDSC_7289 (3) by Mark Hardy, on Flickr
    That's a (roughly) 500 Hz first order XO for a 16 ohm treble driver (with 16 ohm L-pad) and an 8 ohm "woofer" :)
    edited May 2017
    I have inquired for some more spec's on the horn as honestly I got NO CLUE on any of that lol. From the pictures (shown again below) I think they are setup to handle either 2 bolt or 3 bolt, but beyond that, no clue.
    Yes, I do want a basic 2 way as I figured that would be the best and easiest implementation of things.
    The tweeter specs are below:
    Power handling: 60 watts RMS/120 watts program above
    Recommended crossover of 1.6 kHz/12 dB slope •
    Impedance: 8 ohms
    Frequency response: 1,000-18,000 Hz
    SPL: 108.5 dB 1W/1m
    The woofer specs I think your wanting are:
    Power Handling: 600 Watts
    Impedance:8 ohms
    Frequency Response: 48 to 2,600 Hz
    Sensitivity: 96.2 dB 1W/1m
    So the drivers do have a decent amount of overlap to play with.
    Wayne also had this to say (which was before we talked drivers)
    Me: My room is fairly small and I don't have two corners to do a corner loaded setup but am open to any other suggestions or discussion about how to put them to good use. My basic thought is a basic 2 way with a 10" driver for the midrange and low end, but I'm by no means a speaker designer so I wanted to get your thoughts
    Wayne: What you describe would work pretty well. It would be sort of like a mini-VOTT, with a horn tweeter mounted on top of a vented cabinet. I would suggest a high-efficiency 10” or 12” driver that is capable of smooth response up to 1500Hz or so
    My preference on crossovers is something super basic and simple that works well. I'm trying to keep the number of parts at a minimum so I can justify spending a bit more on GOOD parts since there are not a bunch.
    I'm not stuck at all on active or bi-amping and honestly that may be just WAAY beyond what I want to get into.
    edited May 2017
    So, Wayne's advice sounds good to me! :)
    Do you have any information about the horn you are using?
    Ok, I'm dumb here, but you mean the thing in the pictures (that I'm calling a horn, but maybe its not a horn lol)? If so, the answer is no not yet, but I'm working on it.
    You know what I might think about doing? (bwa-hah-hah-hah-hah-hah-hahh!)
    It might be tonnes of cheap fun to use a high sensitivity, high Qts "fullrange" woofer on an open baffle topped with your horn/driver and augmented with a subwoofer.
    The nice thing about a driver like an EV SP12B is that it will have extended, relatively flat (and relatively musical!) response well into the midrange.
    Picture this:
    Extended range, high Qts "woofer" on an open baffle with a choke to roll off response above, say, 2 kHz (first order; i.e., 6 dB per octave).
    First order 2 kHz XO to the B&C compression driver mounted on your horn and a variable L-pad to adjust the HF relative to the LF
    optionally:
    Add an active subwoofer crossed at, say, 50 Hz (adjust to taste).
    I -- ahem -- have a pair of very interesting drivers that I could send you to try "on approval" :)if you wanted to try something like that.
    25746164081_f146a5e611_b.jpgRCA LS15 rearview by Mark Hardy, on Flickr
    25214682053_94ba53c713_b.jpgRCA LS15 cone by Mark Hardy, on Flickr
    That's an OEM version of an EV "Wolverine" LS-15 driver that someone circumsized (de-whizzered) :blush:
    I'll also look at/for/think about vented enclosures & the woofer Wayne suggested.
    (and give others a chance to weigh in!
    I'll also look at/for/think about vented enclosures & the woofer Wayne suggested. (and give others a chance to weigh in!
    Love your idea's but I'm gonna wait for others thoughts and what Wayne suggested as its a known recipe if you will, so I'm not having to re-invent the wheel.
    Here is what I think your asking for:
    Those horns are made by Bill Martinelli and they’re 800Hz horns with a conical throat and hybrid expansion. They’re not CD, but relatively close, and benefit from mass-rolloff compensation just like CD horns do. They mount a standard bolt-on 1” driver.
    DSkip wrote: »
    Try to get Luther on board as well. PM him as it might draw his attention to it better than an @. Luther has the best set of horns I've ever heard and its all because of HIS work.
    Will do.
    Yes, you should get all the info you can (or, at least, all that you want); my approach is "off-center" for sure ;)
    Yes, that's the horn info needed; those are reputed to be very fine horns -- it does sound like they'll benefit from CD horn EQ, though -- the easiest way ;) to do that is with an active XO; many of them have the CD EQ built in; just flip a switch!
    By all means, PM Luther! You can PM a group of folks if you wish, too (just sayin').
    I WANT ALL THE INFO lol... I'm speaker dumb so I want try to go KISS while still getting high fidelity lol....
  • erniejade
    erniejade Posts: 6,315
    Not sure if this will go to the midrange you would need for a 2 way but, Scan-Speak and SEAS makes some great drivers
    https://madisoundspeakerstore.com/approx-12-subwoofers/scan-speak-32w/8878t01-revelator-13-subwoofer/
  • erniejade
    erniejade wrote: »
    Link no workie
  • erniejade
    edited May 2017
    erniejade wrote: »
    That one looks interesting, and I do like the price.....
    Since you do a lot of music & DJ'ing using pro audio type drivers, what frequency do you think are MUST HAVES from Left/Right
    DSkip wrote: »
    Hey Doc,
    I hope that didn't come across as a nudge against you as that wasn't my intention. I just don't want him to miss out on another great resource.
    Nope, not at all!
    I love to give advice -- but I always worry about the consequences of anyone taking my advice! :) It's always good to get a second (or more) opinion!
  • Wardsweb
    Wardsweb Posts: 905
    Have you thought about a nice two way? Maybe an Econowave? As pretty as the horn is, you will want to show it off. How about a bass cabinet with the horn sitting on top?
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Wardsweb wrote: »
    This is what I was trying to drill into the young padawan's head but clearly he weren't listenin' t' me none.
    edited May 2017
    Wardsweb wrote: »
    I thought that was what he wanted to do -- maybe I misunderstood?
    edited May 2017
    Wardsweb wrote: »
    ZLTFUL wrote: »
    Wardsweb wrote: »
    Actually that's what I'm shooting for. Are the drivers I linked too not the right ones?
    txcoastal1 Posts: 13,134
    Here is a pic of the horn used by Wayne, back in 2005 in a 3way design
  • littlewoodboats
    Would something along the lines of a Jensen Imperial horn cabinet work for bass drivers? The Doc's 15's might work well in that application.
    An Imperial with the right woofer would be bitchen (I would opine).
    Plans are available, thanks to Pete Millett, at http://www.tubebooks.org/file_downloads/Jensen_spkr_plans.pdf
    An Onken cabinet could be dandy too -- I do get the opinion that he wants to keep it fairly simple, tho'.
  • pkquat
    pkquat Posts: 748
    I too would vote for an exposed horn, but I don't know what that does to the sound. Otherwise a nondescript box with an open front to show off the horn would be my low cost option. A beautiful woodgrain box would be the high cost option. @mhardy6647 's EV suggestion seams like a good match for a clssic sound and similar matching efficiencies. My novice knowledge though doesn't know how that big woofer can accurately reproduce the upper frequencies.
    I didn't see dimensions for the horn. IMO if you wan't to keep the overall size small, I would recommend a 8" woofer or possibly a 7". I think you will get a better sound in a smaller box, or more bass than larger driver in too small of a box. This should work well for smaller rooms. 8" drivers in a long or deep ported box can dig pretty deep. Its been a while, but I think peerless had some very good 8", and scanpeak had a few 7" and maybe 8 that were fast and could dig deep.
    What I don't know is how much these horns throw the sound. I have heard some horn combinations with a 10" or 12" woofer in a smaller box. The bass rolled off fast, but the woofer could handle some compensation. What did stand out is that they could fill a larger room with thump down to their roll off much more than a smaller 7-8" woofer.
    edited May 2017
    Were those photos of the horns (which are beautiful) & their throats actually there before? I did not see them earlier today :blush:
    You don't happen to live anywhere near New England, do you? :)
    They were indeed there earlier today lol...
  • littlewoodboats
    I have the plans linked and have done the cad work for our panel cnc. If someone wanted to buy the plywood and pay shipping that would be the only cost. I can provide a tongue and groove kit that should be simple enough for a home builder.
    Got anything smaller lol... My room is 10 x 14, if that. A 3 foot wide x 2 foot deep x 4 foot tall would take up darn near the entire room lol...
  • pkquat
    pkquat Posts: 748
    edited May 2017
    txcoastal1 wrote: »
    WOW I missed this pic while I was typing. Lovely!!
    What are the dimensions of the horn opening? Would the horns sitting on top of a floor standing cabinet roughly the size of RTA 8T or 11T be acceptable? Klipsch Heresy size? Smaller, more bookshelf size?
    edited May 2017
    so -- here's a thought.
    Howzabout the venerable Eminence 12LTA twincone as a woofer?
    https://www.parts-express.com/eminence-beta-12lta-12-full-range-pa-driver--290-409
    Inexpensive, sensitive & decent sounding. These will have plenty of output up to 1500 Hz (or even higher) to cross over to the horn and driver of interest.
    There's a cabinet design PDF on the PE page above; it looks -- like a weird choice to me (quite small, so F3 is pretty high.
    Years ago, during the 1990s fullrange driver craze, the late John Wyckoff built a pretty nice speaker kit (Hammer Dynamics Super 12) using the 12LTA augmented by a 'supertweeter' mounted (sort of) coaxially. The performance in a big vented box ('stuffed' with -- styrofoam peanuts!) was pretty darned good.
    http://www.enjoythemusic.com/magazine/equipment/0600/super12.htm
    http://diyparadise.com/hammer.html
    Here's a guy using one with a Pass amp design :)
    https://www.passdiy.com/gallery/projects/184/reed-rehorst
    Here's a serving suggestion a little closer (perhaps!) to the intent of this thread:
    https://www.thomann.de/pics/bdb/141336/7382425_800.jpg
    This is interesting because it includes a so-called "H-frame" (open baffle) "sub"woofer.
