Need matching Atmos speakers to Polk Monitors
I'm trying to find two ceiling speakers to match my current setup:
Monitor 70 Series II x2
Monitor CS2 Series II
Monitor 40 x4 (getting rid of two so I don't have to find a way to mount them in the ceiling)
I want to have two Atmos speakers in the ceiling and think I found some that would be a good match for the 70s and CS2. It is this pair: Polk Audio 80 F/X RT
Will those work or is there another pair of in wall speakers that would be better?
  • dereknitrorc
    What ceiling speakers would anyone in here recommend? Trying to keep it at $300 or less for the pair.
  • codycatalist
    codycatalist Posts: 2,662
    I might be incorrect but it being a "height" speaker you shouldn't need to worry if it is timbre matched. Usually that is critical for left right and center but surrounds not so much.
  • mrloren
    mrloren Posts: 2,456
    MC60
  • dereknitrorc
    Good to know. Thank you!
    mrloren wrote: »
    MC60
    Placed an order for these, if they don't work out, then I can upgrade them later. Thanks!
