Polk PSW450 with 60hz AC power
gtovini
Is that an issue? I would of course have a step down transformer for the 220V.
Best Answer
You asked about 60Hz in your title, so I assumed this is what you have. But, in either 50 or 60 Hz the sub will work fine. The internal amplifier operates from DC voltages, so once the power supply converts AC to DC the rest works accordingly. Under some power supply designs there could be slightly higher noise with 50Hz, but I don't believe this will be a problem with the PSW450.
Cheers, Ken
Answers
Hello,
Welcome to Polk's forum. The PSW450 will operate correctly with 60Hz AC power providing the voltage has been reduced to 117 volts.
Regards, Ken -
Hi Kenneth,
thank you for your fast response. Am I to assume that you typed 60HZ but meant 50HZ? -
Sorry my bad, my all issue was with the 50HZ they have where I am moving. Thank you for your help.
