Can there be more that one accepted answer to a question, and is there an order?
pkquat
Best Answers
Answer 1
Answer 2
Answer 4
Answers
Answer 3
Accepted answers are in post order.
A little too early in the morning to be this drunk.
woahLexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends -
That "answer" deal really screws up the flow of a thread. Another part of the nightmare known as Vanilla. Please don't use it.Political Correctness'.........defined
President of Club Polk -
I hate the answer button
It throws you back up to the top of the thread2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
In with 16. Thanks!
Agreed and noted for future questions. On some forums if you have more than one best answer it either only allows 1 or it puts the last one you selected to the top, and sometimes will not allow you to re-select an answer to change the order. They kept the original thread order and often put the thread post number with the answer.
I like that the best answer(s) are at the top, but not that vanilla re-orders the thread. Very poor design. -
The best answer as selected by the OP may very well not be the best answer and therefore someone else seeking information may be mislead. The "answer" button is a bad idea any way you look at it.Political Correctness'.........defined
I thought I was wrong once, but I was just mistaken.If you can't hear a difference, don't waste your money.
