Disconnect block???
LittleCar_w/12s
Does anyone know of such a thing as a disconnect block? IE. where it allows you to disconnect your power and rcas quickly? like without 4 different kinds of allen wrenches etc?
I know it means a security problem, it's easier to pull the system, but I plan on finding a way to hide such a mechanism, and I'll be using security bolts for the box (I'm thinking the special lug-bolts and weld a matching nut to the frame to bolt it into...)
One of us has got to have seen something like this out there... they make distro. blocks.. why not disco. blocks?
-Jerry
-Jerry
___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself.
Post edited by LittleCar_w/12s on
why not just pull the appropriate cable out of a distro?It's not good, very fundamentally simply not good. - geolemon
there is something where you can disconnect the power wire from the battery, or at least stop any power from going through it, its like $5. it connects to the battery terminal, if thats the kinda thing your looking for.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
no, what I'm looking for is something I can mount to my sub/amp-rack assembly on the edge, where it will allow me to pull the whole thing out without having cables lying everywhere... a place to terminate the incoming wires, and a place to run the assembly's wores to... if no, though, I can build a harness for it n/p but I was looking more along the lines of a hard-mounted block.___________________________
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
ive heard of something like that for power wire...
for your rcas you can just get the shortest rca you can find and connect that with your main rca using a butt connector or something
I'll probably end up making some sort of a plug-style harness...___________________________
perhaps combine two functions into one... put an inline fuse in the power cable, then you can just unscrew the thing and pop the fuse out when you need to... maybe 20 seconds tops... i vote cody's way for rca's, except they'd have to be really high quality connectors, or you will hear the difference... or, depending upon the headunit you've got... : my pioneer has a small pin plug that is female in the HU, and splits into 3 pairs of rca's:
if you have something like this, maybe there's an extension cord of some sort to go in the pin plug, and you can disconnect the rca adapter from that more easily (i.e. a foot from your HU rather than on the back)?It's not good, very fundamentally simply not good. - geolemon
i have radio shack gold series y-splitters...they work great
how would they be applied here?It's not good, very fundamentally simply not good. - geolemon
