WTB : Polk Passive Radiator Pair
RuSsMaN
Anyone have an extra set of 12" or 15" pr's?
Cheers,
Russ
Cheers,
Russ
Post edited by RuSsMaN on
Russ, You only looking for those two sizes?"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar" -
Pretty much, I need to load a bit of mass on them. 10's might work.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Got two 10's out of a 15tl, you want em?"Its worked so far but we're not out yet."
Possibly, do you know if they came from the front, or rear on the 15?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
One front, One rear, just had the one cab that these came from."Its worked so far but we're not out yet."
Thanks for the offer, but I'll pass. The 15 had 2 different (weighted) pr's - one front and one rear, tuned to different freqs.
I'm looking for a matched pair to start with, for a stereo sub project.
Cheers,
No prob., guess I should post this in another thread but how hard is it to calculate for a passive? Also I was looking at these the other day and the only difference in the rear passive from the front one is they added another puck. Could the one be removed without effin the passive up?"Its worked so far but we're not out yet."
Most PR's are simple weighted, and easily adjusted. If it is the same model PR, then yes, add/remove is fine...for the application. I wouldn't drop or add weights just to experiment, as the work was already done for us....if it worked better, it would.
If it is a different PR, then you have a curveball.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Tell you what, I thought of another project they would be usefull to me in, bring them to the gathering, fair nuff?
Cheers,
Cheers,
Russ
Roger that."Its worked so far but we're not out yet."
