BiAmp Rti12 Help
I have 2 Adcom 545 that I want to use on a pair if Rti12. One amp for the lows and one amp for the highs. It'll be processed through my yamaha pre out. Can I remove the jumper between the binding post and let the rti12 crossover handle the seperation? Or how should I do it as I have never done anything like this before.
Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either.
    txcoastal1 Posts: 13,134
    You will need a Y-cable to split the output signal to each amp
    Remove the jumper on the speakers
    Run a separate speaker cable from each amp output to each pair of terminals
  • dalylaleahthor
    txcoastal1 wrote: »
    So basically they can use the same signal?
    txcoastal1 wrote: »
    Yes
  • dalylaleahthor
    Thanks Txcoastal.
