Not a bi-wire thread
I purchased a pair of advertised new, old model MIT AVT bw2 12ft speaker cables couple of weeks ago off Ebay. I ordered new iconn Regular Banana plugs that screw into the cable ends from MIT (there were none in the AVT box).
Banana plugs connect tightly onto the threaded wire ends & fit very nicely into the back of the 705's and A3020. The bw denotes bi-wired, 'love having the bi-wiring pre-finished, no jamming double wires into my 3020 speaker connects.
These things are a hunk of cable, they stay where you put them and do not appear to cause undue strain on either the speaker or amp connects. The ends are marked high & low for connection into the speakers.
As disclosed, discussed & debated on the last giant Bi-Wire thread, what you hear is what you hear.
To my inexperienced and un-nuanced ears my system sounds better with these MIT cables. I was using Amazon-bought nothing special speaker wire, bi-wired into messy connections at my amp.
Sound is fuller, more detail coming through the speakers and a bigger sound. High volume listening is less stressful as peaks are smoother. Thanks F1nut & others for prodding me forward. I know these are low end cables, there is a difference, where to next?
PS do the cables have a break in period?
    tonyb Posts: 32,906
    Normally they do.....but it takes time and you'll probably not notice since it happens slowly.
    Glad you like them, if you never just simply tried for yourself, you'd never know, right ? That's all we ask of people. The higher up the chain you go, the differences become more pronounced...given your electronics is of similar quality. Your not going to put 800 buck cables on Monitor 7's.....know what I'm sayin' ?
  • ukcolin99
    ukcolin99 Posts: 286
    Agreed & thanks Tony. Figure the garden hose-like diameter of these cables allows more signal to flow into speakers that are capable of handling it to produce better quality sound. Might be tempted to try MIT cable for the center although for me this is all about 2 channel music into the 705's. Cannot imagine trying to run these cables to my surrounds or the Monitors that are 50ft away.
    tonyb Posts: 32,906
    Don't mistake garden hose size for quality, MIT has more to it than that and I've heard some similar sized cables I wouldn't use on anything.
    I'd suggest not wasting your coin on upgraded cables to surrounds, unless you enjoy 5.1 music. Otherwise, the magic rests in 2 channel.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Those avt 2 bi wire retail for around 700$ msrp! I use the avt3 bi wire for my front 3, a very nice solidly built cable. would love to try something higher up the MIT food chain sometime, like shot guns or magnums. But looking at some serious coin for those.
    2 channel:
    Theater:
    tonyb Posts: 32,906
    That's why you have to find them used or on clearance.
    F1nut Posts: 49,840
    I get the impression you think what is inside is massive gauge stranded wire. That's not the case at all. MIT cables use multiple runs of unique configurations plus the networks to produce the better sound quality you hear.
  • mikeyb128
    tonyb wrote: »
    Definitely agree. Have had my eyes peeled on both. Still in the 600$ range though. But a great deal considering retail is 2000$.
    2 channel:
    Theater:
  • vcwatkins
    vcwatkins Posts: 1,993
    ZCords were recently a very good deal too. Picked up 3. Good power cables!
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Like yourself cbridle I joined up here and was using cheap bare wire but from mono price. I was on the fence about cables and just wanted a high quality low cost upgrade. It was not until that MIT had a sale and Itool the plunge and scored a whole 4 pairs of AVT for my HT and it really opened my eyes not just to cables giving me more but everything! Good to hear your loving them but it gets really expensive the higher you climb that ladder so enjoy staying where you are right now.
  • ukcolin99
    Thank you F1n, you are correct, keep sharing your knowledge. pfb, noted and agree I'm gonna enjoy what I have for a while. Thinking the Yamaha, 705's & AVT's are a good price/performance match for 2 channel musical enjoyment for at least 6 months....
    Toolfan66 Posts: 16,945
    Funny I just ordered a set of MIT Shotgun S3 Biwire.. I'm not expecting much change if any from my standard Shotguns but I got them for a great price I had to have them.. LOL!!
  • mikeyb128
    One pair of shot gun s3 on MIT clearance....489$... Only if our loon wasn't so crappy right now.
    2 channel:
    Theater:
  • ukcolin99
    I saw the shot guns luckily they were only 10ft, saved my wallet some pain. They are gone now. I see MIT Cables has a new(ish) forum on their web site, maaan there's some member's w/fancy hardware on there.
    I got them hooked up last night, I won't make any assessments till later, but I also added Pangea AC-9 PC's to my amps as well..
    I am now running full MIT Shotgun S3 cables and Pangea PC's throughout my system..
  • Hermitism
    Hermitism Posts: 4,205
    I think my very first post in this forum was about bi-wire. At the time, I thought clear coat speaker wire was the only thing available to connect speakers. I also thought the larger the gauge, the better. So I came up with this brilliant idea, I wanted to take two individual cables of clear coat wire and run them to each speaker, creating a thicker gauge form of transit for the signal. So I joined the forum to ask about my brilliant idea, not knowing that bi-wire cables existed. I thought I'd join an elite group of audio enthusiasts by being the inventor of a new type of cable. I was going to be rich! Yeah...that worked out brilliantly!
    So FYI, I'm actually the inventor of bi-wire cables, I just thought of the idea a couple decades too late. I'm a late bloomer, I guess.
  • sribulusu
    Is there is a significant/noticeable difference when you biwire? I recently got the monitor 60 (T600) towers for cyber Monday sale. My JVC amp (RX7000) shut down with flashing "overload" past volume level on 50. Any thoughts?
    tonyb Posts: 32,906
    sribulusu wrote: »
    The monitor 60's are fairly easy to drive by most any gear. I would check your speaker connections at both ends, speaker/receiver. If your using bare wire connections, make sure none of the rubber coating is caught inside the posts or stray wire touching another from another post. As always, use some quality cable too.
    .....and keep the volume down if that doesn't solve the issue.
