KT-88 Tubes
Faustin
Looking for 4) KT-88 tubes for a Yaqin amp. Currently using the stock tubes and would like to upgrade to Black Treasures or something on that level.
There are lots of treasures on the bay $250 for a matched quad.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I will take a look
heinney9 has been talking about those C wings for awhile and it has me wondering how this would sound?
http://www.ebay.com/itm/Matched-Quad-4x-NOS-Svetlana-SED-Winged-C-6550-KT88-tubes-/181370828458?pt=LH_DefaultDomain_0&hash=item2a3a8b36aa2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
^^^^^^^Hmm. Might be worth a try -
Nearly every amp that will run a KT88 will run a 6550 and vice versa. For all practical purposes they are equivalent. The Wing C 6550s are a great power tube, but beware of some of them sold on the web. Apparently some poor quality ones managed to get out into the market. The Tube Maze store which is listed in the link above is a good, reputable seller. I've bought several tubes from them with no issues whatsoever. Them and Upscale Audio are your two best sources for Wing C 6550s.
FYI the Black Treasures have given me some reliability issues in the past. They sound great, but my Rogue 88 Magnum and Treasures just don't seem to get along. Gold Lion reissue KT88s sound really good and are relatively reasonable. They are a very warm, smooth sounding tube. The only negative I've found with them is though they have good low end extension, they lack mid-bass slam compared to some of the others. They are great tubes for jazz and vocals.
The Wing C 6550s have more slam and are better suited for rock and high energy classical. My very favorite of the KT88/6550 types are the NOS GE 6550s followed by NOS Tung Sol 6550s. Both can be prohibitively expensive however. The Wing C 6550s or Gold Lion's are your next best answer provided the type of sound you are looking for and that you get the Wing Cs from a reputable source. -
Thanks DF for the input. Yes, with the cost of some of these tubes it makes it expensive to experiment and roll. I did see a quad of RCA nos 6550's listed on the Bay for $350.00. Intriguing, but again for that kind of money they better be the right choice.
I am getting good sound with the eh kt-90.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
I will offer something different to consider. I have been using the KT88SC tubes in my VAC amp. Originally these were only avaliable sourced through VAC or from Penta Labs. They are Shuggies with solid plates (no holes). Rumor has it they were designed off the original Genelex KT88 tubes which were also solid plates. Originally avaliable only during limited runs they are now avaliable at The Tube Store as their "preferred series". I am presently running a quad for The Tube Store. These are a sweet deal to research and consider at this price.
http://www.thetubestore.com/Tubes/KT88-Tube-Types/Preferred-Series-KT88
integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Thanks for all the input from all. Now I am really torn as to which way to go!
LOL yeah me too and I don't need anymore (or so we tell ourselves)2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
There's always a need for ...... more.integrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
Just try the EH KT88 first and maybe save some cash in the long run. I always seem to go back to these. I did like the Treasures a lot but they didn't last long enough in my amp and I had one blow prematurely also.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Thanks dragon for the suggestion. They are much cheaper than most other KT88's.Are there more than one EH Kt88 versions? Any suggestions on reputable sellers?
On the high end of the cost spectrum at thetubestore, I note the EAT KT88 Diamonds are going for $450 each! Fair price/performance? Now who has tried those?
http://www.thetubestore.com/Tubes/KT88-Tube-Types/EAT-KT88-Diamond
I have a quad of the EAT KT88s I won on FB from Prima Luna over 2 years ago.
I have used NOS Tung Sol 6550, Treasure KT88, EAT KT88s and TS KT120s. Seems I am missing one but cant remember the name off the top of my head, anyway the EATs are the best in the bunch in my Wright Sound Company amp.
Personally I would like to try the ones Doctor R suggested. The treasures were second in my system if that helps.
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Jim McShane,,,,good pricing,,and he stands behind his tubes. My last purchase was a quad of KT 88's from him.JC approves....he told me so. (F-1 nut)
