Bottlehead Crack
  • mrbiron
    mrbiron Posts: 5,711
    Good job...nice and clean.
    Now I wanna see your big @ss crack!
  • ALL212
    ALL212 Posts: 1,556
    edited May 2015
    B.A.C. will be a bit. I think next weekend I get the o'scope out and start comparing some wave forms on these.
    1st most apparent difference is SLAM! Bass is much better on the modded Crack (then again is a couple of hours on the stock one for burn in really fair?)
    For those of you about to CRACK... I've overheated two power switches and one headphone jack out of the BH kits while soldering so go easy when working with those components. Easy to replace but you either have to get your own (cheap and fast) or wait for BH to ship new ones (free but slow).
    Aaron
    Enabler Extraordinaire
  • mrbiron
    ALL212 wrote: »
    Thanks for the heads up! How were you able to identify that the switches and jack were fried? Was it after completed and the meter readings didn't line up or did they just not work?
  • ALL212
    ALL212 Posts: 1,556
    Power switches - they might not move once they've been overheated but the jack I didn't find out about until readings didn't line up.
    Jack - there is an easy mod listed on the Bottlehead forum under the Crack for an easy change to the jack - basically cut the ground end going to the jack an extra inch longer and ground the outside pins together. Explanation on the forum.
    I have part numbers from either Mouser or Digikey for a Cherry switch replacement and the headphone jack I got from...somewhere.
    If you want I'll look those up.
    Aaron
  • mrbiron
    Only if you have them at an arms reach.
    Otherwise, i looks like i need to get my read on in the BH forums.
    SCompRacer Posts: 8,352
    ALL212 wrote: »
    For those of you about to CRACK... I've overheated two power switches and one headphone jack out of the BH kits while soldering .....
    Are you still using that propane torch to solder with? ;)
  • agfrost
    agfrost Posts: 2,421
    SCompRacer wrote: »
    I believe he said he's upgraded to oxy-acetylene.
    Jay
  • ALL212
    ALL212 Posts: 1,556
    edited May 2015
    It's not easy but I manage to use one of our plasma plate burners out in the shop. It can only do about 12" of steel at a time but if you turn it down just a little you can solder with it. It's not one of those "redo" type operations - get 'er right the first time or order another kit.
    Aaron
  • ALL212
    ALL212 Posts: 1,556
    Headphone jack - this is just one model up from what is supplied: Parts Express Neutrik NMJ6HC-S 1/4" Stereo Part # 090-976
    Still hunting for the power switch
    Aaron
  • ALL212
    ALL212 Posts: 1,556
    Power switch - Mouser: PN 540-LRA22H2FBBNN MFG Part No:LRA22H2FBBNN
    LRA22H2FBBNN CHERRY Rocker Switches
    Both of these are drop in replacements.
    Aaron
  • ALL212
    ALL212 Posts: 1,556
    SCompRacer wrote: »
    They shipped Eros phono's up to the day before I ordered mine! I'm on vaca next week! Talk to them, will you?
    You got a status on this thing yet?
    Aaron
    ALL212 wrote: »
    "Eros phono preamp Orders through 5/3 shipped."
    I'm 5/4.
  • mrbiron
    I feel your pain. "Crack orders shipped through 4/15"
    Voltz and I are the 17th....Son of a!
    mhardy6647 Posts: 33,049
    edited May 2015
    maybe that's a Euro-style date -- the fourth day of the... umm.. fifteenth month...
    sort of like
    Yeah, I'll get that to you. How does the second Tuesday of next week sound?
    I thought of that too
  • mrbiron
    I have a tracking #!!!
    Voltz, you should as well. Check your email!
    I have a "guy" who happens to be an automotive painter, of 40 years, that i know on a very "fatherly" level that has agreed to paint the plate for me as well as the top of the transformer. The problem is, it has to be the color of a car that he is painting as he will not make a special run just for me. He's got 3 colors that i have deemed acceptable. Black, Graphite, Dark Blue......i might even attempt White but i dont think im going to be too fond of it. I didn't plan this originally but i want to have fun with this one.
    Either way, the creative juices are flowing like wine....
  • voltz
    voltz Posts: 5,384
    Got my tracking #. not sure what to do with the plate yet! like the stock photo's.
    Should I build the crack without the speedball 1st like the say?
  • mrbiron
    That's my plan...start stock. Since i don't really need it, my build will take a little longer.
  • ALL212
    ALL212 Posts: 1,556
    You don't have to but it is a bit of a pain to try and "stream" it in during the build. Can be done but you've got to read ahead to figure out what to leave out and what wires to setup ahead of time.
    Easier to build without - listen and then appreciate what it does for you.
    Aaron
  • voltz
    voltz Posts: 5,384
    me too, I have a Schiit Valhalla 2 and a WOO WA3 already but couldn't resist. I may let some of the others go later. and hoping I keep the Crack :)
  • mrbiron
    ALL212 wrote: »
    SOLD! I'm going to do the same with the tubes as well.
  • ALL212
    ALL212 Posts: 1,556
    A suggestion - do read through the speedball directions to figure out what you are going to remove and after identifying those components make an effort to NOT wind them down 100 times on the terminal before soldering. Will make removal much easier!
    My AF training had us make good mechanical connections before soldering. Works nice on aircraft stuff but these kits aren't going to be landing on aircraft carriers or pulling 10 G's so you don't have to go nuts securing before soldering.
    Aaron
  • voltz
    voltz Posts: 5,384
    Well my Crack was delivered today!
  • ALL212
    ALL212 Posts: 1,556
    is it done yet? is it done yet? is it done yet?
    Aaron
  • mrbiron
    YEAH!...hurry up!
    Mine doesn't show up until today and then i gotta get my plates off to the painter.
    Thinking Black at this point.
  • voltz
    voltz Posts: 5,384
    I finished it last night! then I woke up and realized I was just dreaming :(
    Still trying to decide on what color to stain it and paint it :p
  • voltz
    voltz Posts: 5,384
    Well my Crack Box came out nice, did a little lite sanding and its all but ready to stain and then I thought maybe I should wait to finish it till after I built the thing!
    I can't decide what to paint the plate with yet!
    voltz wrote: »
    Rattlecan? Brush?
    (ducks and runs for cover)
  • voltz
    voltz Posts: 5,384
    I been to the bottle head forum look at everyone's stuff and Aaron sure has a lot of pic's there :) thinking about the hammered or textured paint.
