SDA-SRS Binding Post Plate Project
stogie
stogie Posts: 230
edited August 2014 in Vintage Speakers
I had the aluminum discs laser cut, then I drilled the appropriate mounting holes. Then they were powder coated. Finished off with Speakon interconnects and Cardas binding posts. Douglas Connection supplied the DIY parts to build the speaker cables, interconnect cable and jumpers (cable, cable sleeving, cable splitters, spades, bananas, heat shrink tubing). More importantly Doug was only a phone call away to offer assembly advice and tips. Great guy and great company. http://www.douglasconnection.com/ I hope the pictures are attached- I'm having a hard time figuring how to manage attachments.
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
Post edited by stogie on
  • Mystery
    Mystery Posts: 2,546
    edited August 2014
    Nice!
    Toolfan66 Posts: 16,946
    edited August 2014
    Awesome!!
    Looks Great!!!
    F1nut Posts: 49,842
    edited August 2014
    Nice job!
    FYI, Trey (VR3) sells brushed aluminum binding post plates pre-drilled for the SpeakOn and binding posts.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    edited August 2014
    Very, very nice work! With new binding posts and new jumpers, I'm sure the improvement is not subtle. N'joy!
  • nspindel
    nspindel Posts: 5,343
    edited August 2014
    As F1 says, Trey has a very similar item. I recommend an Armacell seal around the perimeter.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited August 2014
    very nice work... You didn't happen to make 2 sets did ya?
    Garage | Polk Monitor 5B's
  • halo71
    halo71 Posts: 4,574
    edited August 2014
    Wow those are sweet!
    --Gary--
  • dhlogic
    dhlogic Posts: 26
    edited August 2014
    nspindel wrote: »
    Armacell has a number of product lines, what did you find that works the best?
  • nspindel
    edited August 2014
    Believe it's called Armaflex? Same stuff as the driver and pr seals.
  • motorstereo
    motorstereo Posts: 2,053
    edited August 2014
    Nice job!
    Do you have a link? Seeing how nice those plates came out is making me want a pair now.
  • dhlogic
    dhlogic Posts: 26
    edited August 2014
    nspindel wrote: »
    http://www.homedepot.com/p/Armacell-2-in-x-30-ft-R-1-Foam-Insulation-Tape-TAP18230/100539553
    Looks like 1/8" thick is only option and what everyone is using, just wanted to make sure I purchased the right thing. Thank you.
    F1nut Posts: 49,842
    edited August 2014
    www.vr3mods.com
  • stogie
    stogie Posts: 230
    edited August 2014
    The nice comments are appreciated. To address a couple of posts above (I don't know how to use the quote thingy)
    Armacell/flex as linked above from Home Depot was used to seal the plates. (torqued down over several days to compress the foam)
    I made 3 sets of plates- but the extra 2 are earmarked for other SDA projects. (pictures as they are finished)
    Thanks again
    TT: Technics SL-MA1
  • audio_alan
    audio_alan Posts: 770
    edited August 2014
    Nice job, Stogie! It sounds like there would be multiple interested parties (myself included) if you made a big run of these...
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited August 2014
    Very nice work.
    Maybe some etching or screen print for labeling, just in case anyone else ever needs to fool with the connections, would be a nice addition.
