Monitor 7 "TL" Project
westmassguy
This was a fun project. Started with nice, clean, late model, Monitor 7 crossovers. The 5B SL3000 schematic was used as a reference. All caps, resistors, and Hi-Pass inductors were removed. Sonicaps and Mills MRA-12s were used throughout. As usual, a 5.8uf shunt cap was installed, and the Polyswitch was replaced with a .5 ohm Mills Resistor. The existing .22mh Hi-Pass shunt Inductor had to be changed to a .27mh @ .5 ohms. A 22 gauge would have been close, but that gauge is not a stock item from my regular suppliers. A .3mh, 20 gauge Jantzen was chosen. The Inductor was unwound to .27mh, and a .2 ohm resistor added in series to equal the required .5 ohm DCR for the shunt. All resistors were mounted to the underside of the circuit board to keep the top side clean, and provide room for the new shunt cap. New standoffs, and new riser boards for the large Lo-Pass shunt Caps were installed. Cardas Binding Posts topped off the project. Lastly, some wire management was done, and the Tweeter's ground leads had 3/16" female spade/quick-connects installed for the new RDO-198-1 Tweeters.
Home Theater/2 Channel:
dhsspeakerservice.com/
Post edited by westmassguy on
Nice work, very clean, all the work you post looks great!Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
ThankHome Theater/2 Channel:
dhsspeakerservice.com/ -
Very Cool!!! I'm looking forward to your evaluation of how they sound once everything is put back together. I see you're putting in new tweeters -are you thinking about rings or anything else?
GHT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100 -
Very nice Dave. Will the cabinets get some new veneer??
gmjungbluth wrote: »Very Cool!!! I'm looking forward to your evaluation of how they sound once everything is put back together. I see you're putting in new tweeters -are you thinking about rings or anything else?
GHome Theater/2 Channel:
Very nice Dave. Will the cabinets get some new veneer??Home Theater/2 Channel:
IDK what all that means but it looks nice.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
as always, nice work...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
IDK what all that means but it looks nice.Home Theater/2 Channel:
Very nice work, and here I thought I was on the sauce for wanting to do my little 5's...no TL mod mind you but upgrade the stuff inside...must make for a decent upgrade in the sound quality department.Home Theater/2 Channel:
This is a serious question :-P
Does adding the additional volume (i.e., the huge caps and additional layer of stuff, if I am interpreting the photos correctly) to the XOs have any substantial (audible) impact on the enclosure volume (i.e., more to the point, tuning)? -
mhardy6647 wrote: »This is a serious question :-P
Does adding the additional volume (i.e., the huge caps and additional layer of stuff, if I am interpreting the photos correctly) to the XOs have any substantial (audible) impact on the enclosure volume (i.e., more to the point, tuning)?Home Theater/2 Channel:
Thanks - just wondering how much that impacts the calculated resonant frequency and other parameters of the cabinet -- presumably not much, but then again, most aren't linearly related to volume (as I recall).
I would imagine that a .0077% decrease in the internal volume would be negligible. The smaller Monitor 4s and 5jrs could possible be affected, but they usually have less components in their crossovers anyway, so it's probably a wash there too.Home Theater/2 Channel:
ThanksHome Theater/2 Channel:
Just like to say David does fantastic work and the Monitor 7's sound better than new, any one out there thinking of upgrading there crossovers I would highly recommend David. I will be upgrading the crossovers in my SDA SRS 1.2TL in the near future and David will be contracted for that build also.
Just like to say David does fantastic work and the Monitor 7's sound better than new, any one out there thinking of upgrading there crossovers I would highly recommend David. I will be upgrading the crossovers in my SDA SRS 1.2TL in the near future and David will be contracted for that build also.Home Theater/2 Channel:
