binding post jumpers
mr_natural78
mr_natural78 Posts: 82
edited November 2013 in Speakers
I just got a set of rt55i speakers finally. Picked them up pretty cheap. One of the drivers needs replaced. They are also missing the binding post jumpers. Anyone know of a place to get these? Could I just put some spade connectors on a few short pieces of speaker wire and use that? I don't see why that wouldn't work fine but wanted to ask in case I'm missing something.
Sony KDL-55EX500 TV
Sony BDP-S570 blue ray player
Onkyo TX-NR809 receiver
Front L/R: Polk RT55i
Front high: Polk RT25i
Center: Polk CS245i
Surround: Polk RT35i
Sub: Polk PSW505
Post edited by mr_natural78 on
  • helipilotdoug
    helipilotdoug Posts: 1,230
    Your idea of making jumpers with speaker wire and spades should work and sound better than the stock jumpers. Go for it!
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • mr_natural78
    I ordered the replacement driver for the rt55i yesterday. I also made some jumpers with spades on both ends and some 6' wires for them with 14awg ofc wire and banana plugs on both ends. Excited to replace the driver and put them to use!
    Sony KDL-55EX500 TV
    Center: Polk CS245i
    Sub: Polk PSW505
  • ThirdWorldGuy
    ThirdWorldGuy Posts: 39
    Could you post pictures please I want to do the same thing but have no idea on how to do it :(.
  • Geoff4rfc
    Geoff4rfc Posts: 3,014
    This procedure is pretty much one of the easiest upgrades you can make. Have any extra speaker wire laying around???
    I'm using 12awg, it's as easy as plug and screw
  • ThirdWorldGuy
    Are there any connectors on the jumper cables e.g spade connector? Do they even need connectors?
    F1nut Posts: 52,182
    Geoff4rfc, by running your speaker cable thru the power port you are disrupting the carefully designed air flow and inducing unwanted vibrations to the cable itself. Also, never coil your cables. Lay them out like a snake to take up the excess length.
  • ThirdWorldGuy
    Excellent observation F1nut.
  • Hermitism
    Hermitism Posts: 4,341
    I learn something here everyday! The cable to my center channel is much longer than I need it to be. I see no other choice than to coil it, what is the disadvantage of doing so?
  • zane77
    zane77 Posts: 1,696
    When you coil the wire it tends to act as an inductor and can induce unwanted noise. If you have to coil it do it in a figure eight pattern this will help cancel the noise.
    Two Channel
  • Hermitism
    Thank you! I'll give that a try.
  • Geoff4rfc
    Thanks, I'll make the change. I had set that up that way to take any stress off of the connections. And please, call me Geoff
  • Geoff4rfc
    How's this................
  • zane77
    zane77 Posts: 1,696
    Mo' betta'
    Two Channel
  • ken brydson
    ken brydson Posts: 9,064
    Geoff4rfc wrote: »
    How do you pronounce that, Goof? :cheesygrin:
    EndersShadow Posts: 17,743
    Geoff4rfc wrote: »
    Nah, I think Imma call you Sally :smile:...
    F1nut Posts: 52,182
    Perfect! Now, all you need are some cable elevators. :cheesygrin:
    You got it.
  • mr_natural78
    Received my replacement driver in the mail today and replaced the old one. Got them all hooked up and calibrated. Sounds killer. The rt55i are such great speakers!
    Sony KDL-55EX500 TV
    Center: Polk CS245i
    Sub: Polk PSW505
  • Hermitism
    zane77 wrote: »
    What about power cords? Same thing or is it a non issue? My power conditioner has a long cord and it just happens to be located directly in front of the electrical outlet. So the cord is way too long.
    F1nut Posts: 52,182
    Same thing.
  • Hermitism
    That you, sir. Since the end of the year is approaching, I'd like to nominate myself for the Dumbest Noobie of The Year Award. Top prize is a speaker connection cleaning kit and a Polk hat. But since I'm a dumb noobie, I'd need instruction on how to use both. ;)
  • zane77
    zane77 Posts: 1,696
    Everybody starts at the beginning at one time
    Two Channel
  • mr_natural78
    Hermitism wrote: »
    lol. That's funny. :)
    Sony KDL-55EX500 TV
    Center: Polk CS245i
    Sub: Polk PSW505
  • Hermitism
    That should have read, "thank you, sir." My tablet auto corrected me.
  • mr_natural78
    freaking auto correct. I hate when my phone does that. I've send some odd texts before because of it.
    Sony KDL-55EX500 TV
    Center: Polk CS245i
    Sub: Polk PSW505
