Realistic STA-77a I just restored
jcaut
jcaut Posts: 1,849
edited March 2013 in 2 Channel Audio
Just wanted to share a picture or two of my dad's old Realistic receiver I've been working on. He bought it new back in '77 and used it regularly up until the mid 90's. At some point it developed a problem in one channel and he had it serviced through the local Radio Shack store. I'm not sure it was ever really fixed, though they did replace a capacitor and a couple of resistors, but I think the real problem was simply due to dirty switches. Anyway it ended up sitting on a shelf in a spare bedroom, unused for probably the last 12 years.
When I brought it to my house, I opened it up and found several obviously leaking capacitors, as well as all but one of the dial lamps out, and VERY dirty inside (parents live out in the country, on a dirt road, and they like to leave their windows open a lot). I disassembled it, re-capped the power supply, amplifier board and phono preamp. Removed the output transistors and heatsinks - mostly to clean them- and then replaced them with new thermal compound. I replaced all the dial lamps and had to fabricate a new lamp holder for the tuning meter lamp because the old one was broken (don't know why).
Anyway, feeling pretty good about the electronics, I turned to the "oiled walnut veneer" case. It was in pretty rough shape, but the veneer was all there and there were no deep scratches. The finish was rough, though, as if the veneer was trying to crack and curl up along the lines of the grain in the wood. I consulted with F1nut about the best method of dealing with the case, and he advised me to clean the surface thoroughly with paint thinner to remove previously applied oils, sand smooth, and apply wipe-on polyurethane. Once I started sanding, I discovered the surface was actually rougher than I realized. I was scared to sand it completely smooth, afraid I'd go through the thin veneer. I got the surface as smooth as I felt that I could, then applied 4 coats of wipe-on poly, rubbing the surface down with fine steel wool between coats. I think the result looks great! Looks better in person. It's not really as dark and red as these pictures make it look, but it's still lighter than the original finish was. It also shows more variation in the wood, which I like. I used gloss poly, which is not really what I had in mind when I started, but it's what was available locally. The gloss level is actually very similar to the "freshly oiled" look. I was kind of proud of it overall! Thanks again for the help, Jesse!
This receiver was "New for '77" and sold for $259.95 18W/channel. Nice tuner that really pulls in stations better than anything else I've got currently. It sounds really nice- Better than I remembered, especially through "vintage" speakers (Dad also has the matching Nova 7b's which I haven't worked over yet, but plan to). I'm not sure what it is about the sound of these old- especially the low-wattage - 70's SS receivers. I like 'em.
Post edited by jcaut on
  • RamZet
    RamZet Posts: 792
    edited March 2013
    Looks nice.
    B&W CM9Classé Sigma
  • jcaut
    jcaut Posts: 1,849
    edited March 2013
    Thanks! I always thought the yellow/orange dial was cool too. And dial pointer that changes from white to red when you tune in a stereo station..
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited March 2013
    The case came out nice,another saved from the landfill.
    Good job.
    Dan
  • thsmith
    thsmith Posts: 6,082
    edited March 2013
    I am speechless, great story and beautilful receiver. I bet your Dad is extremely poud.
  • jcaut
    jcaut Posts: 1,849
    edited March 2013
    Maybe he'll just let me keep it..:cheesygrin:
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2013
    looky what I found on page 10 :cheesygrin:
    http://www.radioshackcatalogs.com/catalogs/1977/
    F1nut Posts: 49,832
    edited March 2013
    Damn nice job, it looks brand new.
    If and I say if you want a satin sheen you can order the satin wiping poly online.
    tonyb Posts: 32,906
    edited March 2013
    Congrats man, she looks great. What you describe in that old sound is like a warm blanket and a cup of hot chocolate. A very easy on the ears sound that you could just fall asleep to.
  • jcaut
    jcaut Posts: 1,849
    edited March 2013
    Thanks again for the compliments! Actually I'm quite happy with the gloss.
    And, Tony, yes that's a pretty good description. It does seem to have a very relaxed sound quality that's very easy to listen to. I don't know if it's really the sound, or if it's just the memories that it brings back. Simpler times. I would have been about 7 years old in 1977. Dad got this receiver, the Nova 7b speakers, and a turntable, along with a few albums of Christmas music (also sold at Radio Shack at that time). I vividly remember all of us sitting down for the first listen. It was the first "real" hifi system I'd ever heard and I was amazed. That experience is probably largely responsible for the way I am about music and audio equipment today, lol! As such, the sentimental value is much larger than the actual value, if you know what I mean.
    I started putting together my own Realistic system, a piece at a time, around 1983. I still have some of the components, but I really wish I had my receiver and my speakers back!
    mhardy6647 Posts: 33,066
    edited March 2013
    cute!
    You know about this site, yes?
    A wonderful resource for R/S stuff (and, up to the early 1960s, many other brands as well). You'll find the STA-77A on page 10 of
    FWIW, an unsuffixed STA-77 (oops, I take that back - it's an unsuffixed STA-52, sligtly newer) passed through here a few years back, courtesy (of course) of my favorite local vintage emporium...
  • allstock
    allstock Posts: 136
    edited March 2013
    Nice! makes me want to get started on the STA-2300 sitting on my bench. Bought it brand new!
    Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
    HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
  • lanchile
    lanchile Posts: 560
    edited March 2013
    Wow, very nice job!!! I had an old Marantz 2238B long time ago and I loved it! for sure they do not make these kind of gears anymore. The best choice is to change all those old electrolytic caps that with time they dry-out and change values. adjust dc offset and bias and that gear will last for another 20 years more...But since you replaced most of the caps, it will perform like new! Again you did a very nice job!
    Make it simple...Make it better!
  • schwarcw
    schwarcw Posts: 7,328
    edited March 2013
    Very nice job! It looks great!
    Carl
  • charley95
    charley95 Posts: 908
    edited March 2013
    I have an old STA-7 from the 1982 catalog. I use it out in my garage. It's starting to slowly fail. It's never been capped or anything through the years. It had some type of bass enhancment for the small Minumus 7 speakers. $179 back in 82. I don't know if it's worth getting it looked at or not. It was a really sleek looking amp back in the day. Man, what a long time ago, I was a senior when I got this thing.
  • gmjungbluth
    gmjungbluth Posts: 232
    edited March 2013
    Great job! And congratulations on bringing a piece of family history back to life!
    I had a Realistic STA-790 receiver (a few years newer) that I really liked. I also now have a pair of Realistic Nova 6B and Nova 8 speakers. The build and finish on them are both great - definitely rivals to the Pioneer and Sansui units of the era. I recapped the 6bs and noticed a pronounced improvement in the upper range. This was an easy job and well worth the Dayton caps and 15 minutes with the soldering gun that it took. The crossovers in these systems are very easy to get to. I'd recommend a recap, and if you need to a clean of the veneers - I used Howard's Restore a Finish on mine and it worked wonders.
    Enjoy!
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
    edited March 2013
    charley95 wrote: »
    The STA-7 is a nice looking and overall very decent piece of hardware; the "slowly fail" description makes me wonder whether it might simply need to have controls, switches, and pots cleaned of decades of dust and oxidation products... this can be a DIY job with a screwdriver, a can of CAIG DeOxit and an owner with the gumption to read a "how to" sticky at a forum (perhaps this one has one; audiokarma definitely should). Don't ditch that STA-7, though, whatever you do! :-)
    As to the advice throughout this thread on replacing electrolytic capacitors - it's very sage advice. The caps weren't really "designed" to last three or four decades; they are probably out of spec at least in terms of ESR (their "equivalent series resistance") - perhaps in their capacitance value, too - and any in the signal path will lilkely result in audible degradation of the signal. The one caveat I'd offer is to tread lightly in the "receiver" section of a tuner or receiver; some of the capacitors are elements of tuned circuits for radio reception; even slight changes in the absolute value of those critical components may de-tune the tuner sections to the point of inoperability (and re-alignment of an FM receiver isn't really a task for a tyro).
    Just wanted to share that thought.
  • jcaut
    jcaut Posts: 1,849
    edited March 2013
    I agree on the "tread lightly" advice regarding the tuner section. I really think as long as you stick with replacing the electrolytic caps it would be fine, as I figure most of the "sensitive" stuff would use better capacitors anyway- But "if it's not broke don't fix it" is definitely good advice on the tuner. I -did- fiddle with mine a little, but I'm perhaps a little crazy or one of those "know just enough to be dangerous" types :cheesygrin:. But without the proper tools and a service manual, DIY tuner alignment is not generally an area you want to get into. I have a schematic, but not an actual service manual for this one- If anyone has access to a manual, I'd appreciate the spec for bias current on the amp. I think it's fine the way I've got it, but I'd still like to check.
    I love the Radio Shack catalog site! I had several of those catalogs virtually memorized, and so it's a lot of fun going back through them. Looking at the '82 catalog, on page 21 and 22, I had -still have, actually- the 31-2000 ten band EQ and the LAB-395 turntable. Briefly had a pair of Mach 1 speakers. Always wanted the STA-2080 receiver, but end up getting a,... well, what model was that? 860 maybe? I'll have to look it up. Probably in the '84 or '85 catalog. I sold that receiver a few years ago to a guy who REALLY wanted it (and offered me way too much to pass up). It was in perfect condition..
    Jason
  • jcaut
    jcaut Posts: 1,849
    edited March 2013
    And, yes, it was an STA-860. Page 10 of the '84 book.
    edited March 2013
    If you're like me, and if you like the Radio Shack catalog scan site... you'll love this site!
    www.alliedcatalogs.com
    The same fellow is responsible for both sites; they're both unbelievable resources.
  • charley95
    edited March 2013
    I think I'll put my STA-7 back in the closet and maybe find someone to tune it up for me someday. I'm not versed enough in electronics to even tinker with caps., resistors...
    I still have my old Denon 1025RA Reciever that will get garage duty for now. What a shame, I paid $875 in 91 for it and now it's only worth about $100. I'll just keep it. It sure doesn't hold a candle to my Rogue. I'm a die-hard tube convert now.
    edited March 2013
    Just don't ditch that STA-7 without... umm... letting a few folks around here know :-)
    Back on-topic, the STA-77A in the original post certainly looks great!
  • charley95
    edited March 2013
    Yep, Sorry for the drift!
    edited March 2013
    heh - seven vs seventy-seven... not much drift at all, really; just one digit :-)
  • dbeckowitz
    dbeckowitz Posts: 1
    edited February 2017
    all these comments are old --- 2013. I don't know if anyone will read down to mine, but I wanted to chime in. ... The STA-77A was my first stereo. I was a semi-well known semi-starving artist, secretly designing LOGOs and print ads under the table for local companies and ad agencies in Seattle. Also, I wrote and produced some radio spots here and there. I recorded the music at a big time Seattle studio ( Kaye-Smith ) and was there introduced to really spectacular recording equipment. I don't remember the electronics, but all playback was done through JBL L-166 speakers. So the L-166 sound became the reference point to my ear and in my head, and to all my recorded product.
    And that's what I needed to demo to my clients ... usually in my apartment. But at that point I had no equipment at all.
    I looked all over for a stereo that could simulate that sound. Nothing worked. Not even close. At least not with any speakers I could afford. L-166s would also have pissed off every neighbor in my apartment building as well. So they were out. Also they cost absurdly huge bucks.
    Anyway, ... operating within my limited budget, I settled on this system: SpeakerLab 1s (an 8 inch 2 way)... from a kit company in Seattle ... an AIWA flat panel cassette player I nabbed from Kaye-Smith ... a Pioneer PL-115D turntable ... and the Realistic STA-77A receiver.
    In the end, I almost randomly chose the receiver. I had accumulated the other equipment a piece at a time. I had just finished assembling the speakers (the glue wasn't yet dry) but I had a client on the way and I was desperate for playback.
    The STA-77A was a pitiful 18 watts, but it looked better than that, and it was on sale at the Radio Shack just a couple blocks from my apartment for less than 200 bucks.
    The client and I hooked it up together, and I punched in the cassette.
    As it turned out ... the STA-77A played back the taped material I had mastered at Kay-Smith perfectly ... and thru 90 dollar 2-way Speakerlabs that I'd slapped together myself. ... ALL the instruments were clear and in balance, right where I'd put them, and at the appropriate individual depths. The detail was just right. ... It was a little hisssy ( signal to noise rated at only -45 db ... and it was cassette after all ), but that didn't matter to the client, who needed to hear what I heard in the studio.
    And, astoundingly, he did. ... except for the hiss, which maybe nobody actually heard but me anyway.
    This story ends like this: Over time a couple buttons gave me trouble, and I was living a bit too close to the ash from Mt St Helens when it went off, so I eventually discarded the STA-77A and "upgraded" to Kenwood 8300 separates and a KX-1030 three head cassette player. I ran these through Rogers LS9s that I purchased from George Martin in London. I love that system best. I still have that system. And a couple others from the same era. But with the advent of craigslist I found myself scouring the Northwest for my old STA-77A. Few have survived. The one or two that have were just too beat up to try to restore ... I don't do that kind of thing myself either. The SpeakerLab 1s were the extent of my DIY in the electronics field.
    Anyway ... just a couple weeks ago, I found one advertised about 30 miles away. Some into it type guy had located one in astoundingly good physical condition and the dumb b*****d had restored the whole thing to new. And he wasn't kidding. And he only wanted 75 bucks for it.
    I drove the 30 miles there and back through the most horrendous traffic, and I gave him 80 without blinking. And without listening to it either. Times have kind of changed.
    When I tested it at home, I hooked it to some Boston HD9s and played one of my 40 years old master cassettes from Kay-Smith. That dumb b*****d had done a really good job.
    And for a mere 18 watt receiver, so had Radio Shack.
    I'm not sure yet where I'll eventually listen to it. As of now I'm just happy to know it's there.
    Thanks for reading this. I'm glad I found a place to tell this story.
    dbeckowitz
    msg Posts: 9,476
    Enjoyable reads here, fellas.
    Similarly, I enjoy the little STA-84 I inherited (read: stole) from my dad.
    Simplicity and nostalgia mostly, I think. Whatever it is, sessions with that piece are always pleasing.
    This is an old thread, so I may have mentioned this before -- but there were a couple of the old Radio Shack "Realistic" receivers which have somewhat unique and (I think) superior aesthetics.
    To wit, I'd like to find one of these one day.
    I like that 'gunmetal' finish.
    source: www.radioshackcatalogs.com (1979)
    or this variant, from 1981:
    pitdogg2 Posts: 24,609
    You know some of these RS products PUNCHED WAY above their price point...
    Too bad nothing RS did in the last 20 yrs. could even come close to their price point..sad to say the least.
  • erniejade
    erniejade Posts: 6,315
    One of my first receivers was a realistic sta820. I think it was actually fostex made.
  • Jetmaker737
    Jetmaker737 Posts: 1,009
    Cool story dbeckowitz. Speakerlabs were the **** way back in the day.
    SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|Nakamichi RX-202 Cassette
