Music Library
best app for android for what? playback? I typically use Poweramp since it plays all my hi res FLAC files w/o any issues. If you're streaming from your NAS, probably MediaHouse Pro + Poweramp.
I actually just migrated all my blu-ray rips and my FLAC collection to a Synology DS413 NAS (4 x 3TB); it has LMS for the Squeezeboxes, media server, video / audio station for direct streaming, and even supports Airplay via Android.
So +1 for the NASALL BOXED UP for a while until I save up for a new place
Home Theater:
KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs -
So +1 for the NAS
Playback flac and my ripped uncompressed movies and dvd'sHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
bigaudiofanatic wrote: »Playback flac and my ripped uncompressed movies and dvd's
Connecting to your DLNA server, browsing your media: MediaHouse Pro
FLAC Playback: Poweramp Pro
MKV/M2TS/AVI/MPEG2 (dvd): MX Player or BS Player
You browse in MediaHouse and when you click on a file, it'll ask you which app you want to open the file with.ALL BOXED UP for a while until I save up for a new place
Home Theater:
2 Channel:
THe only problem with Media House is it looks for a server, sense the hard drive is just seen as a shared folder through my router it does not detect it. I am working on a solution for this now.
Over the next week or so I will be doing a complete write up on my story and success with transferring out of itunes. What would be some things you guys would like to know about in the write up?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I currently have 4 zones of SONOS's in my house. I use my iTunes library shared from my main PC that is always on and rdio.com
It's been working great! rdio.com has 95% of what I want to listen to. what they don't have I have in CD form and I rip it and add it to the library that's on my PC.
...this who thread is about ditching itunes?
Can SONOS stream FLAC?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »Can SONOS stream FLAC?
Yep.....but it won't do hi-rez files. You can however upsample by any good dac.HT SYSTEM-
lsi 9's -
Yup, its stuck at 44.1/92 but for me personally thats not a problem. All my stuff is that format anyway."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
bigaudiofanatic wrote: »THe only problem with Media House is it looks for a server, sense the hard drive is just seen as a shared folder through my router it does not detect it. I am working on a solution for this now.
Ahh - was under the impression you had a DLNA server running. OK, then use BSPlayer in 'LAN Mode'. You just add the ip of the NAS (and any login required) and you can browse the shared folder(s).ALL BOXED UP for a while until I save up for a new place
Home Theater:
2 Channel:
bigaudiofanatic wrote: »My library is stored in iTunes _______________:arrowl:insert joke here all in Apple Lossless. With my next purchase being a windows computer I am considering moving it out of iTunes. So I will probably have to convert them too FLAC.
Am I going in the right direction? Also what is a good music library interface, if I decide to leave iTunes but is similar?
I have 4 terabytes of music so I have been there and done that. You are on track for storage, I would consider network storage or home Cloud Storage which makes your files available in to many other devices through your home network both wired and wireless. But there is no need to convert your collection from Apple Lossless it is a lossless format just like FLAC, and APE. I also have a love/hate relationship with iTunes lately mostly hate. What you want to do is load up MediaMonkey it sync's with iPhones, iPads, iPod Touch, etc so you can manage your local files with it. You will only have to sync with iTunes for purchases, App's, updates, and podcasts exclusive to iTunes. Now for conversions there is really only one in my opinion and the is dbpoweramp http://www.dbpoweramp.com/dmc.htm I have used it for years. I have used their batch converter to convert as much as 36 gig's worth of music files all at once it is very fast using each core of your CPU to convert an individual file.
Video files; a video card with an HDMI interface can plug right into a modern HDTV. Windows 8 Media center can be used to control thingsRadio Station W7ITC -
Why bother converting to FLAC? Apple lossless is fine and will work in itunes on Windows. You can get add ons for itunes that will make it sound better.
