imaging question, problem
gmorris
I've been tweaking my R30's placement now for over a week. Each night I'll move them about & see what happens. I think I've finally got it, but I have one question.
I started moving them around to try to clean up the bass. It was too boomy. Now, with the current placement, I think the bass is just right. So then I started to play with the toe-in angle. At first I had too much toe-in, which gave a very focused image, but little soundstage width. So I decreased the toe-in until I got a good balance of image focus & soundstage width. The placement & toe-in I have now sounds just right to me.
On to my question: The center image, such as lead vocals, any guitar that is center stage, cymbals ect... all seem too high. The image seems to be about 1 - 1-1/2 feet above the top of the speaker (but in the middle of course). Is there a way to lower the image, or is it supposed to sound that high?
Bob Mayo, on the keyboards. Bob Mayo.
Post edited by gmorris on
Originally posted by gmorris
On to my question: The center image, such as lead vocals, any guitar that is center stage, cymbals ect... all seem too high. The image seems to be about 1 - 1-1/2 feet above the top of the speaker (but it the middle of course). Is there a way to lower the image, or is it supposed to sound that high?
You can downtilt the speakers to adjust this. I really enjoy the height you seem to be listening to. Just a matter of preference I guess.
HBomb***WAREMTAE*** -
Those speakers are about 33" high, right? If the center image was on the same level, to me, it would seem like there was a band of midgets playing. Good sound reproduction should have width, depth and height.Political Correctness'.........defined
President of Club Polk -
....we represent the lolli pop guild.....
anyway, you think the image height that I've described is about right, hugh? I don't know where it is supposed to be.
also, what, if any, speaker placement adjustments can be made to alter the soundstage depth? or is that more of a function of the electronics, the amp & preamp?Bob Mayo, on the keyboards. Bob Mayo. -
For me, it's about trying to get as close as possible to a live performance, so a center image height should be taller rather than shorter. IMO, depth is a function of all components, but mostly the speakers. I don't know how to get more depth out of a speaker that doesn't have it to begin with. Maybe somebody else does.Political Correctness'.........defined
Excellent advice.
That sounds right to me, that if live, it would sound about that high. I think I'm done with setting them up now. I will just have to enjoy them now & stop being so anal about it.
Rock on!Bob Mayo, on the keyboards. Bob Mayo. -
Another great tweak is to use the spikes to tilt your speakers back a little if the tweeters are below your ears. The trick is trying to get the tweeters on the same level as your ears.
For final adjustments, cut a long piece of string. Tape one end of it on the chair where your butt would be. Measure the distance of one speaker with the string and mark it with a tape. Now check the other speaker. Make sure both speakers are the exact same distance to you.
Maurice
