Tube gear...Finally
Frank Z
Frank Z Posts: 5,860
edited December 2003 in 2 Channel Audio
I finally found some tube gear to play with! I picked up this amp from a guy that was selling it on ebay. The reserve was not met so I made a fair offer and ended up with a pretty decent amp. Here's a link to the original listing.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3053785500&category=39783&rd=1
I also won this preamp. It should get here in a couple of days.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3057879648&category=14974&rd=1
I've got the amp connected to my wifes SDA-2b's, and everything seems to be working quite nicely. I' really like the warm sound.
Comments?
Post edited by Frank Z on
  • gatemplin
    gatemplin Posts: 1,595
    edited November 2003
    Congrats, looks great. I have never heard a tube amp before but am thinking about getting a used one like you did. I heard they are very clean and smooth sounding. Give a review when you get the preamp.
    Graham
    Graham
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Looks like some cool gear Frank. I've had my eye on that preamp also - look forward to hearing your thoughts on it.
  • madmax
    madmax Posts: 12,434
    Frank,
    Try playing something with a lot of sounds on top of each other, you know, something that has too much going on at the same time and just sounds messed up normally. If this amp is like some of mine you will hear all the sounds individually rather than an overall mush that you get from a SS amp. Congrats!!!
    madmax
    Vinyl, the final frontier...
  • Frank Z
    Max,
    Any and all advice is welcome. Got any suggestions for tunes to try out?
  • polkatese
    polkatese Posts: 6,767
    looks great, Frank! congrats...are these going to power LSi9 or the SDA? I would very much interested to hear how they perform with LSi, if you are going to pair 'em.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Frank Z
    Right now it's all about tubes and SDA's, but I'm going to hook up the Lsi9's as well for a mini shoot out.
  • madmax
    Frank,
    The song that caught my attention was Cheryl Crow "the na na song" on the "tuesday night music club" CD. I had heard this song time after time and really knew what it sounded like. The first time I played it on tubes I heard many sounds separately, not the mush between words that I thought the song was. The rest of the CD is great as well. The only thing is that you would have to know the song through SS first, get used to it and then listen through the tubes. I'm sure you will find like sounds in your other CD's you are familiar with.
    madmax
    edit: the reason I say you will have to hear it through ss first is that once you really know what a song sounds like through tubes you will hear the same thing through ss. The mind and ears is a curious thing...
  • RuSsMaN
    Thanks Chuck - I had not pulled that one out yet. I'm going to head to the cave now, and check it out on my tube pre and tube cd player.
    Cheers,
    Rooster
  • madmax
    Being in Rooster mode may turn it back to mush :D
  • organ
    organ Posts: 4,969
    Congrats Frank! Welcome to the wonderful world of tube audio.:cool:
    Your tube amp will sound much better when the tube pre arrives. Adding a tube pre can give a bigger improvement than adding a tube amp with ss pre.
    Please let me know how they sound with your LSi9. Both our amps use a quad of EL-34 Push-pull. I think it sounds amazing with the LSi.
    What tubes are you using? If you really enjoy the tube sound, try Svetlana EL-34. They have the warmest and most romantic sound.
    Maurice
  • Tour2ma
    Tour2ma Posts: 10,177
    very simple, clean look, but for some strange reason I look at that pre and think, "Flintstones' mobile"...
    will look forward to your review...
    More later,
    Tour...
    Vox Copuli
  • madmax
    I see it too. :)
    madmax
  • RuSsMaN
    So it has a roll-bar, big deal. ;)
  • Tour2ma
    maybe it's the key fob remote...
    More later,
    Tour...
    Vox Copuli
  • madmax
    Actually I think it is those rear fenders.
    madmax
  • madmax
    I read the whole ad this time. The remote actually goes with the preamp! I thought it was there to show size.
    madmax
  • Frank Z
    Sorry I haven't kept track of the petty jealousy over my new remote!;)
    Looking forward to getting my new Barney Rubble preamp....
    I wonder if I can mount some off-road lights on the rollbar?!?!:D
  • Tour2ma
    yabba-dabba-dooooooooooo
    More later,
    Tour...
    Vox Copuli
  • Frank Z
    WWWAAAAAAAAAA!
  • RuSsMaN
    Don't you mean 'yabba-dabba-tuuuuuube'?
  • Wardsweb
    Wardsweb Posts: 905
    I like thinking outside the box. Trick little pre. I ended up building a custom one off version of the Bottlehead Foreplay for one of my systems.
  • RuSsMaN
    Dual mono I take it? Looking at the 'connected' volume controls.
    Cheers,
    Russ
  • Wardsweb
    Wardsweb Posts: 905
    You are correct sir. Very simple layout.
  • Frank Z
    Well I’ve been listening to my new gear with mixed results. Keep in mind that I’ve never owned tube equipment before and was a bit unsure of what to expect. I was a little nervous about buying a DIY amp off ebay, but the sale went smoothly.
    The amp is rated at 40x2, and really does sound good. I’ve listen to a wide variety of music on both the SDA-2b’s and on the Lsi-9’s. One of the things that became apparent right away is that 40watts is not enough juice, at least for me. Although the amp provided nice warm sound, it wasn’t able to drive the speakers at high volumes. Distortion was painfully obvious every time I cranked up the volume. 40 watts is 40 watts, no matter how you look at it. One of the things I learned from the guy that built it (via Email) was that I did not need a pre-amp to use the amp, it has a level control built in. It also is switchable from pentode to triode mode. The pentode mode is not as pleasant to listen to as triode. The only real problem that I encountered was some static from the speakers a few minutes after the amp was turned on. It lasted for 30-45 seconds and stopped after the tubes warmed up.
    The sound is sweet, even though the low end does suffer. That’s not to say that the low end disappeared, but the loss of punch in the low range was distinct enough for me to notice. To my ears the SDA’s performed better overall, even though they are a larger speaker. I believe that having the passive radiator made a big difference. The one area that the Lsi’s did sound a lot better was at reproducing piano music, credit the Vifa tweeters. On the SDA’s pianos sounded kind of fuzzy, the detail just wasn’t as good as the 9’s. Mid’s where about the same with as light edge going to the SDA’s. Rock music did not sound as good (on either speaker) as jazz/blues/classical did. I was particularly impressed with the Lsi/tube combo when listening to Mozart –The 5 Violin Concertos by Itzhak Perlman (Deutsche Grammophon Cat #455-535-2). Perlman’s Stradivarius violin sounded absolutely incredible!
    The Dared Pre-amp is small, but it performs well. The only thing that I don’t care for is the small amount of noise from the servo that rotates the volume knob. It’s not a real big deal, just something that I could do without. After listening to the tube amp mated to the Dared pre-amp for a couple of days I dragged out my spare Pioneer Elite M-10x 2 channel amp and went through a lot of the same music. At 75w x 2 @8ohms and 100w @ 4ohms it’s not he most powerful thing on the planet, but it did serve as a point of reference between tube and solid state. The sound was still excellent, but the mid range was not quite as warm. The low end was back, and higher volume levels were available without distortion when needed.
    I used a Sony DVP-C660 5 disc changer as the source. Most of the CD’s were standard redbook titles, although I did play through a few stereo tracks from a couple of Hybrid SACD’s
    Bottom line, the tube amp and pre-amp performed better than I expected as far as sound quality is concerned. I have to admit that I was expecting a bit more as far as volume is concerned. I’m sure that a more efficient speaker would be a good match for the amp, but I’m happy with my Polk speakers and am really not interested in sampling more speakers right now. So I think I’m going to hang on to the pre-amp and use it with my PE amp for the time being. The amp is going to be sold, either here or on ebay. I’m not giving up on tubes, but I’m going to research some more and perhaps invest in an amp that is rated at 100watts x 2 or more.
    F1nut Posts: 49,851
    Frank,
    Nice review.
    I've become a believer in the tube pre/SS amp camp. Just seems to be the best of both worlds.
  • pjdami
    pjdami Posts: 1,894
    Frank,
    Nice review and some good observations. I did get to audition some tube gear myself this past week. My dealer told me that in general, every tube watt amplification is equal to 2 - 3 watts of solid state amplification. So your 40 watt tube amp should equate to 80 - 120 watts of solid state. Most likely marginal for peek LSi performance which is more like 175 - 200 watts (in my opinion of course).
    I listened to some JM Lab Electras (standmounts) and some Spendor S8s on a Rogue audio tube amp rated at 60 watts / channel in a carpeted sound room 15 X 25 ft with a 12 foot drop ceiling and the system never went to distortion .. pretty loud in fact. The source was a Cal Audio Lab CL-15 cdp. Easily 85 - 90 db from the listening position if I wanted it (loud enough for me!). The Spendors are 90 db efficient though and 8 ohms so that may have been a big factor.
    I may be looking into some tube gear to experiment myself on the two channel rig. Of course the Rogue is high on my list but I have also been reading about the Jolida 202b modified tube amp available from Underwood Hi fi.
    Paul
  • madmax
    Frank,
    I used the tube amps on the lsi15's and agree with you totally on the power. When hooked to the SDA-SRS 1.2's the sound level is more than enough but with the '15's it sucks. Maybe the 2B's are not efficient enough? Just keep in mind that a pair of 1.2's really don't take up much more space than the 2B's. Just taller. Don't react too quickly is all I'm saying. Once you get the right speakers with the tubes you will wonder why you ever listened to anything else. Maybe rather than selling the amp it is time to invest in a pair of large SDA's? You wouldn't be sorry. Just an opinion.
    madmax
  • Frank Z
    Paul,
    Thanks F1 and Paul.
    I'm leaning toward some Conrad Johnson gear, or perhaps this....
    http://www.innersound.net/itubeover.html
    Waiting to hear from them on dealers and MSRP.
  • Frank Z
    Max,
    I'm in agreement about getting some larger speakers, but the space just isn't there for 'em.
    BTW, For anyone that is interested, I did put the amp up for sale in the Flea market. Polk-heads will always get first crack!
  • pjdami
    pjdami Posts: 1,894
    I guess I have a question now about tube amps. If one watt of tube amp is equal to two to three watts of solid state (at 8 ohms), then how does this change when you use a 4 ohm speaker like a LSi? What my dealer told me pertains to 8 ohm speakers I'm sure because the speakers I was listening to were both 8 ohms. I'm thinking it should be the same as the solid state rules right?? roughly 75 - 100 % more power or is this a limitation of tube amps?? Seems like 40 tube watts should be a lot if one follows these rules for a 4 ohm speaker unless it is just equally a function of the speaker efficiency.
    P.
