..Carver PM-1200 amp & Carver C-1 preamp
dee1949
....selling for friends retiring South. The Carver C -1 preamp is as Mint as you will find.
The PM-1200 amp was rack mounted and shows wear around mounting holes. Also has scratches on top. Front face is very presentable as are the sides. Puts out 600 watts per into 4 ohms. It is the pro version of the Carver 1.5. Both sound great.
....for local pick up upon audition and your satisfaction.........$440.00
Washington dc 20017.....around Catholic University
Post edited by dee1949 on
For those unfamiliar with Carver. The C-1 preamp:
- GET back to Vinyl - this is an EXCELLENT preamp for use with turntables. Has 2 phono inputs.
- Apart from its various signal-processing features, the C-1 incorporates a full-function preamplifier with all the following:
- Two separate extended-curve phono stages totally free from overload, slew limiting, transient intermodulation distortion, or cartridge interaction.
- Separate bass and treble stepped tone controls for each channel with selectable turnovers and switchable defeat.
- A steep (18dB/octave at 2- Hz) infrasonic filter that eliminates power-robbing record warps or other low-frequency disturbances.
- Tape dubbing/monitoring for two decks.
- Powered headphone output.
- There's also an external loop for other accessories.
Specifications
* Has left and right bass
* left and right treble
* volume, balance, selector dial for: Aux1, Aux2, Tuner, Phono1, Phono2
* Push buttons for: tone, loudness (40Hz) 8KHz-2KHz, external processor, dub 2-1, tape 1 and 2 monitor
* 6 buttons for: hologram injection and separation, sonic hologram, stereo/mono, speakers and power
* Headphone jack
* Back: button for infrasonic filter and 3 switched/3 unswitched outlets
******* Carver PM-1200 amp ******
This was the Updated version of the Carver Pro 1.5 & 1.5 a and the last of the Carver Pro series
Specifications:
Fan cooled, switch selectable
(24) High Current transistors, (12) per channel
(2) 130v, 4800uf capacitors plus (2) additional large caps which I can't see the values (see photos)
Balanced XLR or 1/4" PHONO Inputs ONLY as this is Pro Audio.
......Will include a New high quality pair of XLR to RCA cables for $15.00 if your preamp doesn't have balanced outputs.
Power Output:
1200W into 8-ohms OR 1000W into 16-ohms Bridged MONO mode.
600W + 600W into 4-ohms with no more than 0.1% THD
450W + 450W into 8-ohms with no more than 0.1% THD
300W + 300W into 16-ohms with no more than 0.1% THD
IM Distortion: Less than 0.1% SMPTE
Freq. Response: 3Hz - 80kHz -3dB
Damping Factor: 200 @ 1kHz
Gain: 26dB
Signal/Noise Ratio: Better than 115dB at 450W
Input Impedance: 15k-ohms per leg
Slew Rate: 25V / usec
Dimensions: 19" W x 3 1/2" H x 13 1/4" D
Approx Weight: 25 lbs
>>>>>>>> Feel free to Audition them........I am retired and around most of the time >>>> -
Would you consider splitting them up?Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
....Sale Pending on the PM-1200.
So that's a yes?Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Carver PM-1200 amp SOLD.
The C-1 preamp - $195.00 available for local pick up 20017 -
...The Carver C-1 still available.
....Also have a Kenwood Basic C-2 preamp in excellent condition.....$120.00
...Kenwood Basic C2 Preamp in Great condition. Known for its neutral sound and great phono preamp.
A new phono preamp would cost twice this price,
Features:
- Separate Bass and Treble with selectable turnover frequency
- Turnover freqs set at 200 or 400 on the bottom end and 3k or 6kHz on the top end.
- Phono / Turntable input
- Selector for MM or MC cartridges
- 5 position phono cartridge EQ selector
- Built-in Low and Subsonic Filters to eliminate excess rumble from sources such as turntables. These are selectable for either 58Hz, 40Hz or 18Hz @ 18dB / Oct.
- Hi "Scratch" filter set at 8Khz with a slope of 12dB / Oct. Useful for reducing the 19kHz pilot tone in FM and tape hiss / electronic hiss & noise and record static
- Output defeat
- Mono / Stereo input selector
- Dual Tape Monitors with bi-directional dubbing
- Dual (1 & 2) Aux inputs
- CD Input
- Tuner input
- "Loudness" Boosts Bass and Treble in relationship to Mid frequencies at lower volume levels
- Headphone output with separate level control
- Indicator LED's for input selector
- 3 AC convenience outlets ( 2 switched 1 un-switched)
Original Specs:
Design type: 2 Channels, Analog operation
Frequency Response: 1-350kHz +0 / -3dB
Maximum Output Level: 1V
THD: 0.001% at full rated power
Phono MM Sensitivity: 2.5mv for 5.0V output @ 1kHz
Phono MM Maximum Input Level: 200mv
Phono MM Input Impedance: Selectable
S/N on Phono MM w/ 5mv signal: 94dB
Phono Capacitance: Selectable
High Level Sensitivity (tuner, Aux, Tape) : 150mv
