srs 3.1tl side grill cloth
profsteve
profsteve Posts: 7
edited November 2002 in Troubleshooting
This may sound like a siily question and one that I should know the answer to, but I don't. How do you remove the side grill cloths on the SRS3.1 TLs so they can be recovered?
Post edited by profsteve on
  • jdavy
    jdavy Posts: 380
    I do not think there is a way without taking the speaker cabinet apart. What is wrong with yours?
  • profsteve
    profsteve Posts: 7
    Thanks Jdavy
    The black grill cloth is a bit worn in a few spots and I'd like to make it mint. I am having the front grill clothes redone also.
    F1nut Posts: 49,803
    profsteve,
    The side panels are glued on. To remove them you can try using something like a putty knife for starters and then you'll need something like thin sheet metal. Go slow because they can break, which if they do you just replace them with a new board.
    F1nut
