Can you hook a separete tuner to a receiver
faster100
faster100 Posts: 6,124
I posted this question already on another section and thought i would try here also.... Ok i want a non powered tuner to hook up to get better reception than my HT receiver, Can i plug it into the tape in or cd in so it go's through the receiver and i have all the options available like dsp's and 5 channel and function as if it were internal can this be done. i want a older onkyo or integra fm tuner, any models off the top ya head that are good??
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • hoosier21
    hoosier21 Posts: 4,415
    edited October 2002
    yes you can hook a tuner up to any input except the phone input.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • faster100
    edited October 2002
    Great just what i was wanting to know, does anybody know a good model older tuner by Onkyo or integra? Let me know as i found a few on e-bay, like the T-4087 and T-4041, and some others, i like the 4087 because it has the rosewood side panels like my M-504 amp....
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Libertyc
    Libertyc Posts: 915
    edited October 2002
    Maybe you should try improving the FM antenna on your HT receiver and see if you get better reception. Also turn off your cd/dvd player while using your tuner because they can give you interference.
  • faster100
    edited October 2002
    I actually had a terk circle shaped antenna, then now i have the terk tower and still stinks on reception, always has even with my other Onkyo receiver and i like to listen to radio stuff and have had enough of the crappy reception, i have heard the older tuner separetes work great!! Thanks though
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • mantis
    mantis Posts: 17,325
    edited October 2002
    Check out Terk FM PRO its about 4 feet long and works real nice.You can mount it outside under an eve.Or in the attic.It uses standard RG6 or 59 if you like.
    Dan
  • faster100
    edited October 2002
    WoW e-bay price is around 75-80 bucks, good idea but after 2 antenna's and still shady reception seems like a tuner would be a feasable solution? But.... I could try one from best buy or somewhere i can return it if it don't work or if it does i can return it and head to e-bay for a cheaper than retail one.. good idea i will ponder on this, Just seems like you pay a grand almost for a receiver that the FM tuner should work great not just ok, the rest works like a charm just the tuner...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
