pop when...
MxStYlEpOlKmAn
MxStYlEpOlKmAn Posts: 2,116
edited July 2002 in Speakers
every time i turn my fan off my subwoofer has like a pop...plays fine, but pops when i turn it off...could this hurt the subwoofer in newayz?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
  • mantis
    mantis Posts: 17,057
    edited July 2002
    Let me get this straight,
    when you turn off your fan...I assume a window or a tabletop cooling off people fan??
    It's most likely on the same circuit,I don't see how it's making your sub pop.
    does this happen when the sub is in standby or when your using your system?
    Never heard this one before.
    Dan
  • briancs
    briancs Posts: 193
    edited July 2002
    My Velo does it to with a cooling off the people fan. Only with the fan on the same circuit though. I blame it on the wiring at my apartment. Possibly no groung is allowing interference to seep into the power lines?
    The guy with $40.00 mains and a $700.00 subwoofer.
  • ntculenuff
    ntculenuff Posts: 1,146
    edited July 2002
    my sub was on the same circuit as my ceiling fan and popped when i turned off the fan i just moved the sub too a diff outlet..no more pop
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • HBombToo
    HBombToo Posts: 5,256
    edited July 2002
    sounds like an inductance problem caused by the fan on that line. I would not think grounding would be an issue here?
    ***WAREMTAE***
  • DaMonk
    DaMonk Posts: 8
    edited July 2002
    Ive heard both yes and no as to whether any damage can occur
    try plugging in your sub through the delay on off if this still occurs
    you may want to get a line conditioner
  • MxStYlEpOlKmAn
    edited July 2002
    i plugged it in somewhere else and it dont pop no more...so whatever
    I promised myself
    Damn you all! - ATC
