Need a bass management outboard for your SACD or DVD-A?
PETERNG
PETERNG Posts: 918
Post edited by PETERNG on
  • mantis
    mantis Posts: 17,057
    edited May 2002
    Thanks for the tip.
    For all you Denon owner's..........did you know you have adjustable outputs for your 8 channel in????
    It work's wonder's for DVD AUDIO and SACD.
    Dan
  • hoosier21
    hoosier21 Posts: 4,408
    edited May 2002
    Mantis
    I have a Denon, what are you talking about?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • PETERNG
    PETERNG Posts: 918
    edited May 2002
    I believe the new Denon 5803 and Pioneer Elite 4900 have full bass management control abilities (for 5.1 or 6.1 or 7.1 inputs), the rest have partial or little control, most of others have none...
  • rskarvan
    rskarvan Posts: 2,374
    edited May 2002
    Denon DVD3300 has built in bass management for dvd-audio.
    Very cool.
  • mantis
    edited May 2002
    HOOSIER,
    The 8 channel in you can set the levels.The fixed output of your sacd or dvd audio can be level adjusted.If you own the 3801/2 just turn on the external ins and press the enter key and up will come the level adjustmants, now you can adjust the levels.this is a cool feature for no bass management.Can't do large and small setting but at least you can set up the levels.
    Dan
  • hoosier21
    edited May 2002
    I see watch you are talking about , thanks
  • mantis
    edited May 2002
    Anytime.
    Dan
  • begbie
    begbie Posts: 630
    edited May 2002
    How do you hook up this outboard decoder?
    From dvd player(6 analog cables) to bass manager to receiver(another 6 analog cables) ? That would be a lot of cables.....but what are ya gonna do ?!:rolleyes:
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
