rear center channel suggestion needed
dlew308
dlew308 Posts: 530
edited May 2002 in Speakers
Wow the forum changed after I posted this is the other category <g>
I have the RM7500 with PSW450.
My new yamaha rx-v1200 is coming! I need
a rear center. There's not much space as it will go right behind the couch.
Post edited by dlew308 on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited April 2002
    I would get the cs245(i). Run a comparison and see which one you like up front, it or the rm7500 center....throw the lesser of the 2 to the rear.....
    Cheers,
    Russ
  • dlew308
    dlew308 Posts: 530
    edited April 2002
    what stand would you recommend for the rear center or should i just go with a slim table behind the couch?
  • RuSsMaN
    edited April 2002
    Man, thats a tough call without seeing your setup in person. The Polk store sells some good entry-level Sanus stands (in pairs).
    You can check partsexpress.com and audioadvisor.com for some other options, and pricing on some 'single' stands.
    Cheers,
    Russ
  • goingganzo
    goingganzo Posts: 2,793
    edited April 2002
    i have some cheap speakers like the ones that come with the cheap ht in a box for 200bucks i gave my free r10 to my parents so i took these home with me they are cheap
  • mantis
    mantis Posts: 17,057
    edited April 2002
    NO room for a surround back speaker??
    Try this trick,sit the centerchannel behind your couch and fire it up towards the ceiling.No stand required.This will give you a spacious sound.Full as well, but check this out,not much is going to come from that channel anyway, Don't sweat it if you can't get it to go.
    Dan
  • dlew308
    dlew308 Posts: 530
    edited April 2002
    I bought a narrow table for behind the couch.
    I replaced my RM7500 rears with the F/X300i.
    Should I just use one of the rears for the center or perhaps the $77 CS175i from Fry's?
  • atrain
    atrain Posts: 4
    edited April 2002
    I am gonna claim ignorance... I have never heard of a rear center channel. What purpose does it serve?
  • dlew308
    dlew308 Posts: 530
    edited April 2002
    For 6.1 systems. Normally you'd have a 5.1 setup, 1 center, 2 mains, 2 surrounds, 1 sub. 6.1 adds another channel, rear center. Then there's 7.1 & 8.1....etc etc
    There's not many movies in 6.1 yet, but movies like Gladiator are DTS ES 6.1 :)
  • atrain
    atrain Posts: 4
    edited April 2002
    Excellent, Thanks for the info
  • Dreamnevil
    Dreamnevil Posts: 7
    edited May 2002
    Had the same question not too long ago, found that the peeps here guided me on the right path. I ended up purchasing the cs245i for the rear center. I also had a "where to put another speaker" problem and came up with this idea.
    I mounted the cs245i on the ceiling with a pair or swivel brackets modified for aiming the speaker 45 deg @ the wall directly behind the veiwing area. it bounces the sound off the wall and blends with the f/x300's quite well. I don't know if this helps, but it's an option....
    ~Dreamnevil~
    :D
  • dlew308
    dlew308 Posts: 530
    edited May 2002
    I went and bought a small table that fits begind the couch nicely. I replaced my rears (RM7500) with the f/x300i and put one of the newly spare rears as the rear center for now.
  • aaburto99
    aaburto99 Posts: 17
    edited May 2002
    Dreamnevil, what brackets did you use? Did you use the Omnimount ones suggested by Polk? Seem kind of expensive to me.
  • Dreamnevil
    Dreamnevil Posts: 7
    edited May 2002
    I used a pair TV brackets that was purchased through C.C. that I modified to work with the CS245i. It took a little while but it's worth it. I didn't want to drill holes into the speaker so I had to use something else. That worked for me, and it looks OK..
    heheheh
    :D~Dreamnevil~:D
  • jeberhart
    jeberhart Posts: 69
    edited May 2002
    Along these same lines: My Denon 3801 is 7.1-channel capable, so I'm running L,R,C, sub, 2 surrounds, 2 REAR surrounds -- but are there any 7.1 movies out there yet, especially DTS? I haven't seen any.
  • Dreamnevil
    Dreamnevil Posts: 7
    edited May 2002
    I have been wondering if there are any 7.1 movies out there too! I keep searching but have yet to see it, I guess it's a little ahead of it's time huh?
    If ya happen to find one, post it so I can rent it too!
