Make my own SDA-2 Interconnect Cable
Hi. Anyone know of any links anywhere on the 'net that may have the specs to make an interconnect cable for a pair of SDA-2b's? Part numbers for the plugs, etc. would be very helpful.
Thanks!
Thanks!
Post edited by todd141 on
Well you don't mention where you live but in Canada you can just visit here
They have all the info and the parts you'd need.
Mike -
I looked through that site but couldn't find connectors that would fit the SDA's. Where are they? I need one as well.
Thanks,
OKay somebody fill me in on just what type of connector these speakers use. I haven't the foggiest notion what SDA-2's look like or what sort of special cable they need.
Mike -
My brother and I found the pin-blade ends years ago but don't I don't recall where... have to think on that one.
This is a shot of a blade/blade SDA cable (w/Brother Mike's Polk SDA demo switch) -
Shot of an SDA 2B.
POLK DOES NOT HAVE THESE IN STOCK AND NOT MAKING ANYMOREDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I heard a rumour they had one type or the other, I'm not sure which.
Really? They'd better update the list then..
MICAH!!!! -
They have the blade/blade type, they DO NOT have the pin/blade type.Political Correctness'.........defined
President of Club Polk -
Does anyone at least have a close up picture of the pin and the blade?
edit
Now THAT is a working man's fingerCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thank you! amulford!! That helps. I'm going to try and build a cable. From what I understand, the blade doesn't do anything - it's the pin that needs to be connected.
That pin looks about the same size as a banana plug - true? -
Someone could use a speaker cable upgrade.
I know, I know, it's a personal thing...
madmax
Edit: Actually that pin is the same size as the pin on an RCA phono jack.Vinyl, the final frontier...
Yeah I know. It's on the list, but man what a pain in the ****...
It's alot more to it that just hooking up a couple of runs, I have to go thru walls and under floors and yadda yadda yadda..
The BOSS is real tight on that stuff, no new holes, minimal visibility.... -
Man, My hands have been BRUTALIZED!!! I can grill without tools!!!
They still have that soft touch w/ Momma, though!!:D -
OK - I'm now confused. I've seen a lot of posts here in the forums relaying info they have received from Polk saying that the blade part of the cable isn't used, it's only there for "support" or something.
Anyone know the real truth to this? -
I don't think so, for there are two wires in the cable. Now if they only used one plug, why would they have two wires?
I had to cut mine to extend it. I was told to be sure BOTH connections were maintained.
I know, I know, it can be repaired. -
Hey fellers, didn't we used to have a member that built/sold these cables...?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Yea, he was extricated after ripping another member off.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
You don't NEED the blade part. I've used just a run of speaker wire jury rigged into the pin hole and it works.....
I know people and even Polk have said that you don't need both wires, but if you look at the back of the binding post plate you will see that both the pin and the blade terminals have wires connected to them. This makes me go hmmmmmm???Political Correctness'.........defined
Does make you go hmmmmmmmmmmmmm.........
Perhaps Ken could give us some insight. I agree, there has got to be a reason......I mean, why have such a non-standard connection in the first place?
Probably a common ground connection.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Yeah, that would explain why non common ground amps are a no no.
