Handy guide to the "proper" juxtaposition of inductors in crossovers
Saw this uploaded to Flikr & thought it was a simple and handy guide for anyone who's wondering about how to arrange inductors in a circuit to minimize any deleterious cross-coupling between inductors. :)
source: https://flic.kr/p/Mo3DfH
  • F1nutF1nut Posts: 40,378
    Good post Mark. I saw someone's crossover upgrade recently that could have used that info.
  • gmcmangmcman Posts: 1,209
    @mhardy6647 Thanks for sharing that.
    So does this put the setup for some of our inductors in the "very bad" category? Or does the plastic framework reduce this cross-coupling?
    Web pic of 2.3TL factory inductor layout.
  • mhardy6647mhardy6647 Posts: 19,021
    Any normal plastic should be invisibile to the electromagnetic fields around the inductors. Those two are at right angles, which is good -- their physical proximity is less good, but we're still not lookin' at a worst case scenario -- so all is probably fine.
  • delkaldelkal Posts: 313
    Unless I am seeing it wrong it looks like number 4.............Very bad and worse case scenario
  • VR3VR3 Posts: 22,250
    That is proper placement, no worries
    That placement is not even on the chart and it is fine
    - Not Tom
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    VR3 wrote: »
    Unless I'm seeing incorrectly...looks just like fig 4 when rotated 90 deg.
    edited September 18
    Some info from Pat McGinty (the "Meadolark" guy) on empirically testing for inductive coupling here:
    http://www.hifihaven.org/index.php?threads/a-little-pictorial-guide-on-the-juxtaposition-of-inductors-in-a-crossover-for-diy-or-refreshing.4024/#post-76833
    The problem with the juxtaposition shown in the photo a few posts back is the physical proximity of the coils. It's certainly not optimal, but it is probably, empirically, fine.
    My experience with measuring inductors says that it makes such a small difference that it won't matter
    - Not Tom
    I've found 2, 3 and 8 to be the worst
    - Not Tom
  • steveinazsteveinaz Posts: 18,396
    No, not like #4. His 2 are sitting on edge, neither is sitting flat.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; Belden 1694A Dig Coax | AC Power: Panamax M5300-PM
    edited September 19
    For the record, I'm not doubting how well the crossovers work, and they do with the orientation in my pic..just comparing to the diagram.
    steveinaz wrote: »
    What if we take the pic and rotate 90 deg, then instead of looking at the top, imagine looking at the side...nearest the bottom of this pic.
  • ZLTFULZLTFUL Posts: 4,611
    The point is, they are 90* orientation from each other which helps reduce the inductive interference.
    Greater distance = OK solution
    90* = better solution
    90* + greater distance = best solution
    ZLTFUL wrote: »
    egg-zack-a-tack-ly.
    ZLTFUL wrote: »
    I agree.
    This is also 90 deg. I want to say that #4 is not referring to this, but the 1st pic.
    And again, just curious if either way will make a larger difference, especially in our crossovers.
    I'm not complaining....speakers sound great. B)
    as a truism -- a little more space between inductors is better if circumstances permit. I like to give my DIY XOs room to breathe :) In fact -- why put 'em in the box at all? No real value added (especially if one wishes to... umm... experiment.
  • verbverb Posts: 3,328
    Interesting lesson professor. I found this. Right hand rule. Explains why the orientation and 90 angles can be placed closer together.
    Basement: Polk SDA SRS, Micro Seiki MB14 TT, VTL 2.5 Pre, Marantz CD6006 CDP, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
    Spare Room: Dayens Ampino Integrated, Auris BluMe, Polk TSi200's
    Living Room: Pioneer SX-N30 Network Receiver, Pioneer PD10AE CD Player, Furman M8-LX Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi Subwoofer
  • ken brydsonken brydson Posts: 7,143
    verb wrote: »
    What is this about again?
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
    verb wrote: »
    It's about the "flow" Ken!
    All of the inductor photos are the same as what is shown in figure 4. And if the table is correct it is the worse setup. It doesn't matter if the inductors are placed flat side by side, tilted side by side or even on top of each other on a board. The only thing that matters is the orientation of the copper windings. It is number 4.
    You can se it easier if you put your pointer finger on each hand thru the hole in each inductor. Your fingers will be pointing in a T. No other orientation in the table will do that.
    But is this table correct?
    VR3 wrote: »
    Do you take the measurement when BOTH inductors are hooked up, charged and have a current? Testing one inductor at a time won't show much of an effect. And if the neighboring inductor is not hooked up to anything it will have zero effect (no circuit for the coil to do anything). But when both inductors are charged and acting like a magnet thats when you will have a big effect.
  • Viking64Viking64 Posts: 3,272
    I just want to eat doughnuts.
    Viking64 wrote: »
    Put a doughnut on each pointer finger, look at the chart, play around a little, then eat them!
    If you still don't see it get the next two doughnuts...............
    delkal wrote: »
    Or maybe an electrolytic cannoli?
    gmcman wrote: »
    ZLTFUL wrote: »
    I agree.
    That is the same as #4 because the coils are going in the same direction. That is, if you stood up the one laying down it would be parallel to the one on end. Now, if the one laying down was stood up on end and turned 90 degrees that would be good.
    edited September 20
    delkal wrote: »
    In gmcman's photo the coils are in a "T" configuration, which is ok.
  • agfrostagfrost Posts: 2,160
    gmcman's picture is "none of the above" when looking at the original diagrams. The SDA inductors are placed like this:
    Jay
    SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8
    Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
    Lets just say this is not a handy guide. It is either wrong with number 4 being very bad or that a lot of people can't understand the difference between number 4 and number 6.
    I've been up all night testing these various examples and I still haven't been able to sew the ripped 3/4 sleeve of my Captain and Tennille baseball shirt. :'(
    delkal wrote: »
    Care to illuminate us as to who comprises "a lot of people?"
    Jay
    ...I'll follow up my previous diagram with this one, which I posit is the same as number 4 (and different from the first one I posted). In essence an "L" instead of a "T".
    Not an electrical engineer nor a crossover designer, so I can't wax poetic as to why/how these are different, but my visual-spatial skills tell me there's a difference.
    Jay
Howdy, Stranger!
